Motherboards Error on P5N-E SLI help!!!!
Discussion in 'Hardware' started by decebal_12000, 30 Nov 2009.
  1. decebal_12000
    decebal_12000 Minimodder
    13 Aug 2009
    I have an motherboard Asus P5N_E SLI and I tried to install it with an Intel E6300 2.8 GHz 45nm but when I start the computer it doesn`t POST anything at all.
    I bought an PC Analyzer PCI card and i started again the pc but the code from the card is 18 and it says:"Force an Interrupt and Verify the interrupt Occured". To this error corresponds "18 Detect CPU and Cache, (initialize L1 Cache?)"
    I went on Google and I tried to find out about this error and the error is "18 Test 8259 functionality: force an interrupt and verify the interrupt occurred. " As much I read is about the processor, is it possible the MB is not compatible with the processor or the processor is not good?
    P.S. Sorry for the horrible story and my writing.:wallbash:
  2. unknowngamer
    unknowngamer here
    3 Apr 2009
    Was the system working before hand?
    Also which e6300 is it?
    There are 2....
    one at 1.86ghz and one and 2.8.
    bios details from asus....
    Core 2 Duo E6300 (1.86GHz,1066FSB,L2:2MB,rev.B2) bios: 0202
    Pentium Dual Core E6300 (2.8GHz,1066FSB,L2:2MB,rev.R0) bios: 1301
    So while it may say support the e6300, it might not support the Other e6300.
    You might need an older CPU to update the bios.
    Then it may work with the newer one.
  3. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Did anyone else get nostalgia?
  4. reggie50
    reggie50 Minimodder
    24 Apr 2009
    Have you tried resetting the CMOS so that it loads the defaults only?
  5. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    Did you update the BIOS to version 1301 ?
  6. decebal_12000
    13 Aug 2009
    I reset the BIOS few times all failed but I think I will have to try with another processor to update the bios and to see after that if it will work. My processor is E6300@2.80Ghz;FSB 1066; L2 Cache 2MB; Core 45nm.
    The version of the Bios I do know it because I cannot make the MB to start even to see the BIOS.
    Looks I have to update the BIOS to to 1301 because the other is not supported.
  7. decebal_12000
    13 Aug 2009
    I do not have nostalgia for old components but I have it and I can use the MB because is better than one which I have it in another PC.
  8. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Are you sure, an E7400 has a clock of 2.8ghz, I cba to search it but i cant see intel bringing out 2 E6300 with the same fsb and an massive difference in multiplier :eyebrow:
  9. unknowngamer
    unknowngamer here
    3 Apr 2009
    AFAIK
    I had the same problem with the P5N-e
    When the quads came out it wouldn't even post without the bios flash.
    As the 2.8GHz e6300 is a new chip, the old bios wont know what it is and has a dickie fit.
    If you can get an older 775 CPU in the motherbaord (q6600 should do) to flash the bios, it should then work OK.
    Download the latest bios to a USB drive and extract it. (comes in a zip IRC, whcih cant be read) and use the EZ flash (read the manual) and that should do the trick
  10. unknowngamer
    unknowngamer here
    3 Apr 2009
    I might not be sure, but intel is :)
    http://processorfinder.intel.com/List.aspx?ParentRadio=All&ProcFam=0&SearchKey=e6300&
    SLGU9 2.80 GHz E6300 2 1066 MHz 45 nm R0 2 MB LGA775 06 Intel® Pentium® Processor for Desktop
    SL9SA 1.86 GHz E6300 2 1066 MHz 65 nm B2 2 MB LGA775 06 Intel® Core™2 Duo Desktop Processor
    SL9TA 1.86 GHz E6300 2 1066 MHz 65 nm L2 2 MB LGA775 06 Intel® Core™2 Duo Desktop Processor
    http://processorfinder.intel.com/details.aspx?sSpec=SLGU9
    http://processorfinder.intel.com/details.aspx?sSpec=SL9SA
  11. decebal_12000
    13 Aug 2009
    Yep I sorted out the problem it was the BIOS version. the morons sent me the MB with the 0.703 Bios version. I managed to update with an old processor and it starts now. thank you for help. i will come with updates.
  12. unknowngamer
    unknowngamer here
    3 Apr 2009
    Good to hear you fixed it.
    you were quick too.
    Good job :)
  13. decebal_12000
    13 Aug 2009
    Thank you!!
    I put all components together and are working perfectly.
    Thank you all for your advice.
  14. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Crazy lolz :thumb:
