Storage eSATA hot plug question
Discussion in 'Hardware' started by m0ng0lh0rde, 26 Jan 2010.
  1. m0ng0lh0rde
    m0ng0lh0rde What's a Dremel?
    5 Jun 2004
    Hopefully an easy question. In order to be able to hot plug an eSATA drive, obviously the controller needs to support hot plug.
    Does the external drive also need to support hot plug, or should it not matter?
    Thanks,
    Jason
  2. Modsbywoz
    Modsbywoz Multimodder
    14 Oct 2009
    *ignore*
  3. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    The external drive shouldn't (in theory) make a difference, so long as you have the drivers installed for the chipset on your motherboard. If it still doesn't hotplug and you have the correct motherboard drivers installed, try setting the mode in the BIOS as AHCI.
    m0ng0lh0rde likes this.
  4. giskard
    giskard System builder
    21 Nov 2009
    Which raises this question: if my BIOS is set to legacy IDE mode, can I then set it to AHCI without causing any problems with my existing internal SATA drives?
  5. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    If you're using XP, then you'll need to do a Windows repair install using the correct SATA drivers on a floppy disk.
    Windows Vista or 7 will need a registry entry changing if it was installed on an IDE mode disk.
    http://support.microsoft.com/kb/922976
  6. pimonserry
    20 Dec 2008
    What he said.
    If it doesn't boot after setting to AHCI (it should boot if you have installed all correct motherboard drivers, from your manufacturer) then switch back to IDE emulation, and change the registry like he's said.
    Then back to AHCI, then it'll boot up :thumb:
    (Sorry took ~24hrs to reply)
