Modding Etching on case panel??
Discussion in 'Modding' started by H4wk1e, 3 Dec 2006.
  1. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    I like to etch a picture on the side of my case of a pattern that i have on my pc. (Case is black)
    How can i get a outline of the pattern on the panel to etch of the black paint to reveal the metal underneath.
  2. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Draw your pattern on a piece of paper with a pencil. Place the paper on the surface you want to etch drawing-side down. Rub the white side of the paper to transfer the graphite. That's kindergarten stuff, really. You should test to see if the pencil will stick before applying.
  3. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    that what i thoughtbut not going to really see pencil marking on black case
  4. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    You could rig up some sort of pantograph, that way you could get finer detail.
  5. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    yer that an idea, isnt there any sort of transfer paper that can print it on?
  6. Sphering
    Sphering What's a Dremel?
    31 Oct 2006
  7. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    yer thats a good idea cheers mate, do you know what bit he used to engrave with
  8. mattthegamer463
    26 Nov 2004
    You could put masking tape on the panel, draw your design on the masking tape, and then etch through the tape, then peel it off when you're done.
