Windows Ethernet port on my mobo has forgotten its IP data
Discussion in 'Tech Support' started by Charel, 22 Dec 2008.
  1. Charel
    Charel What's a Dremel?
    23 Mar 2006
    As stated in the title really, had my xbox sharing the internet through it and all of a sudden it just stopped working, I've tried resetting it using the diagnose tool and it just won't do it, nor will it automatically detect new IP settings.
    any suggestions?
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    Remove it in Device Manager, then rescan and reinstall the drivers.
  3. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
    Have you tried ipconfig commands?
    Go to the command prompt,
    ipconfig /release
    ipconfig /renew
  4. Charel
    23 Mar 2006
    tried all that, xbox can now see the computer and stream video, but not share internet.
  5. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    What's your home network setup? Wired/Wireless?
    Can the pc see internet? see the router? Maybe the router needs a reset if you can't.
    What comes up when you ipconfig /all?
  6. Charel
    23 Mar 2006
    everything else is connecting fine.
    xbox is wired to the pc, which is wireless to the internet.
  7. ModMinded
    26 Aug 2008
    Are you bridging your wireless and ethernet connections on the pc?
  8. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    With Vista, open Network And Sharing Centre, then Manage Network Connections on the left, then right-click the wireless connection (the one you use to connect to the internet) and go Properties, then the Sharing tab, then tick 'Allow other network users to access the Internet through this computer's connection'.
    I hate to have insulted your intelligence if you have already done this :/ But that's the only thing I can think of, if the settings have reset.
    Bridging might work to allow your X360 to connect over your wireless, but I'm not totally sure how that works.
