Electronics Eu-61 2.5 Inch Lcd Help Please
Discussion in 'Modding' started by KeTeFLiPS, 20 Aug 2005.
  1. KeTeFLiPS
    KeTeFLiPS What's a Dremel?
    24 Mar 2005
    At my work I found an Printer LCD preview monitor. It looks like it has somesort of 9-PIN connection ( DIN? ), what are the chances I can get this to be a nice little display? :rock:
    I haven't found any info yet but would be happy if anyone might know anything about this. :wallbash:
    Some pictures:
    What do you think? Thanks, by the way! :thumb:
  2. smoguzbenjamin
    smoguzbenjamin "That guy"
    6 Sep 2004
    Hm could be a serial LCD or maybe a 4-bit parallel, although, it could be RGB as well. Bugger me :D Try googling for technical info if you can spot any serial numbers on the PCB or something.
  3. KeTeFLiPS
    24 Mar 2005
    I already did, googling, but not to obtain it anything clear.
    :waah:
    In the case the model is EU-61 and get 5v 0.35A, by the 9DIN sure.
    in the PCB have no model num or numbre.. :duh:
  4. KeTeFLiPS
    24 Mar 2005
  5. smoguzbenjamin
    6 Sep 2004
    Hmm what numbers (if any) are there printed on the ICs? Can you see any traces from the connector going directly to a pin on an IC? Is there anything else that stands out that might be helpful? Remember, it's easier to help you with too much info, than with too little :)
