Hello to all, I hope you rested a little bit in August. Ready to start again with new mods? I'm assembling a PC inspired by the Neon Genesis Evangelion series. I thank immensely thank you who helped me! Hardware: Case: HYDRA NR01 Motherboard: X299 AORUS GAMING 3 CPU: Intel Core i5-7640X VGA: MSI GTX980 GAMING RAM: 32GB S3+ DIMM DDR4 2400MHz C17 (4x8 Gb) https://s3plus.com/it/products/dram/desktop/s3-dimm-ddr4-2400mhz-c17-4gb/ SSD:S3 PLUS TECHNOLOGIES 480 GB SSD X2 https://s3plus.com/it/products/ssd/consumer/ssd-sata-3-0/ POWER SUPPLY: FOCUS PLUS 750 Platinum FOCUS Plus 750 Platinum - Sea Sonic SSD M.2: XPG GAMMIX S10 PCIe Gen3x4 M.2 2280 HD : WD 1 TB Liquid Cooling: Thermaltake 2x Radiator: Thermaltake Pacific RL140 Radiator Radiator fans: 2x Thermaltake Riing 14 RGB Radiator Fan TT Premium Edition Reservoir: Thermaltake Pacific R33 2 x pump: Thermaltake Pacific P1 Black D5 Pump w/ Silent Kit Final pics :
And here are the Ram and the SSD RAM: 32GB S3+ DIMM DDR4 2400MHz C17 (4x8 Gb) https://s3plus.com/it/products/dram/desktop/s3-dimm-ddr4-2400mhz-c17-4gb/ SSD:S3 PLUS TECHNOLOGIES 480 GB SSD X2 https://s3plus.com/it/products/ssd/consumer/ssd-sata-3-0/
On the front of the case HYDRA NR01 you can install a radiator from 360, but I will go to mount two radiators 140 with tank. 2x Radiator: Thermaltake Pacific RL140 Radiator Radiator fans: 2x Thermaltake Riing 14 RGB Radiator Fan TT Premium Edition Reservoir: Thermaltake Pacific R33
now passes to the action with the airbrush on case Hydra NR01 I used the colors Createx and Wicked colors for aerography. The airbrush used for this aerography is iwata HP-CR 0.2 Watch the video
To mount the two pumps (Thermaltake Pacific P1 Black D5 Pump w/ Silent Kit), I created an inclined aluminum support
you're really talented with airbrushing....love the mod too, the pumps placement and the inclined support, great work so far
Well done Warboy Mecha theme with the choices you made with hard tubes, yellow liquid and lights...simply rocks
