Graphics Ever seen this?
Discussion in 'Hardware' started by chewbaccas_nan, 3 Sep 2011.
  1. chewbaccas_nan
    chewbaccas_nan Minimodder
    27 Jun 2011
  2. Wira
    Wira Spoderman
    27 Jan 2011
    isn't it just marketing, I mean, saying that you '2win' by having gtx 460 SLI?
  3. jizwizard
    jizwizard Modder
    24 Dec 2010
    **** really as my 570 can get 6300 points.
  4. chewbaccas_nan
    27 Jun 2011
    Yeah I've never seen this card before, just read a review on it, saying you can buy 2 for cheaper and clock them yourself.
  5. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Your system gets the score, not just your GPU. I got 5819 when I had a GTX470 in my system and CPU @ 4.3GHz, so Aria's benchmark result isn't really anything to go by.
  6. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    The only instance I could ever see single card sli/crossfire for is in motherboards that have only 1 16x slot, like mitx. Otherwise it seems you have always been able to buy 2 regular gpu for less cost than these type of dual gpu cards.
    The benchmark thing is amusing as well. What is 200 odd points really mean anyway? The gtx580 would still be a better choice as it is near enough the same performance in a single card instead of relying on sli which isn't a guarantee in every title.
  7. chewbaccas_nan
    27 Jun 2011
    Yeah I'd still have a 580
  8. jizwizard
    jizwizard Modder
    24 Dec 2010
    i thought 3dmark 11 was just tested on the gpu? as my old phenom system with the same card performed the same?
  9. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    It tests the GPU, but if your CPU (and to a lesser extent RAM) are bottlenecking it then you will get a lower score. For every GPU you benchmark, at some point there is a floor with how low your CPU can go before it effects your results. If i put a 580 in my e-350 system i would get a lower score than if i put it in my 2500k system.
  10. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  11. law99
    law99 Custom User Title
    24 Sep 2009
    hooray for bs marketing! I'm so glad I do marketing now at work. I can lie all the time, but it's alright because the manufacturer told me too!!!
    It has an ingress rating of 56 I swear!!! I know cause it says on the box :)
  12. Farting Bob
    21 Jan 2009
    You dont need to be a marketing genius to see this is just SLI on a stick and not worth the extra hassle it brings to the table.
  13. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    There were a few threads on this card when it came out. Searching EVGA GTX 460 2Win would probably return it.
  14. bulldogjeff
    2 Mar 2010
    I run SLI'd 460 and before that I had the 9800 GX2 (SLI in a box) and I have never had a problem with either.
