News Evercookie will track you down
Discussion in 'Article Discussion' started by julieb, 23 Sep 2010.
  1. hyperion
    hyperion Active Member
    30 Jun 2007
    Like a slave who offers his master a brand new cane.
  2. dyzophoria
    dyzophoria Member
    3 May 2004
    you have a point, I just dont like end users taking the hit for it first, that's all,lol
  3. Micky999
    Micky999 New Member
    25 Sep 2010
    It's beatable, because that's how it works, someone makes something that's a bit arsey, another figures how to destroy it, and they eventually do!
    This will not last long.
  4. Phoenixlight
    Phoenixlight New Member
    29 Oct 2010
    What the **** was the point in making that? it's like making a virus then saying to everyone "hey look at this cool thing I made for your computers"...
  5. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    If it can be done it will be done, such is human nature.
    I'd rather this be released as an open source proof of concept so that it can be dealt with proactively than show up as an actual exploit and then have everyone scrambling to respond to it afterwords.
  6. thehippoz
    thehippoz New Member
    19 Dec 2008
    just run a script to erase all of the relevant directories on login.. done :D
    been doing that for long time.. remember years back even, guys used to think they were clean running private browsing in firefox.. you look in their flash cache and see horsescocks.com and rogain.com
    the only deal running scripts is windows 7 64 bit has issues running certain programs as admin through the task scheduler- found that if you launch a cmd in admin using the scheduler instead, and sendkeys running whatever you need run and exit (a vb script ect..) you get by those limits
    vista had the same sort of quirks so it was easy to implement in 7.. they are almost the same.. if someone put a supercookie on me- it wouldn't stick around more than a day, 1am to be exact!
    here are all the directories you need to clean with firefox.. substitute the xxxx's
    Code:
    target = "C:\Users\Mr. Burns\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys"
    target1 = "C:\Users\Mr. Burns\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\{XXXXXXXX}"
    target2 = "C:\Users\Mr. Burns\AppData\Local\Mozilla\Firefox\Profiles\{xxxxxxxx}.default"
    target3 = "C:\Users\{USER}\AppData\Local\Temp\*.*"
  7. Phoenixlight
    29 Oct 2010
    Sorry for being a noob but I'm guessing you put the code into notepad and put the user account name where the X's are? and what lines of code do you need above and below what you posted to make it run?
  8. thehippoz
    19 Dec 2008
    go into those directories and replace the xxxx's with whatever you need to, it'll be different for everyone.. and the user name {USER} and Mr. Burns above
    here's the rest of the code
    Code:
    on error Resume Next
    Set fso = CreateObject("Scripting.FileSystemObject")
        fso.DeleteFolder target
        fso.DeleteFolder target1
        fso.DeleteFolder target2
                WScript.Sleep 5000
        fso.CreateFolder target
        fso.CreateFolder target1
        fso.CreateFolder target2
    Const DeleteReadOnly = True
    Set objFSO = CreateObject("Scripting.FileSystemObject")
    objFSO.DeleteFile(target3), DeleteReadOnly
  9. Phoenixlight
    29 Oct 2010
    Ok thanks :thumb:
Tags: Add Tags
