Hardware Everise Variable Speed Rotary Tool Review
Discussion in 'Article Discussion' started by arcticstoat, 2 Aug 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    LOL... Talk about timing, I was searching for a Dremel or something to do some small mods to my CM690... U guys read my mind... lol
  3. Jipa
    5 Feb 2004
    It's exactly the same tool sold with a number of brands. It gets the job done, but is noisier and not as refined as the real thing. Also the bits that come with these cheapo tools are largely rubbish, so if you're on a tight budget, get one of these tools, but use higher quality Dremel cutting disks etc.
    My 2cents.
    (for the record I own the 4000, 300, Trio and also a generic rotary tool identical to this one...)
  4. mpr
    mpr What's a Dremel?
    26 Jul 2010
    I love my Dremel kit... It looks like these bits can be used with a Dremel which could save on cost? Not that the Dremel stuff is that expensive.
  5. Xir
    Xir Modder
    26 Apr 2006
    Have you tried unscrewing the black plastic protector thingy between the tool and the collet?
    On my dremel-clone it revealed the typicel thread for the flexible shaft.
  6. [WP@]WOLVERINE
    [WP@]WOLVERINE What's a Dremel?
    18 Oct 2003
    Personally i would never use any of the cheapo knockoffs ive tried a couple and they are just not up to par. When it comes to tools its always better to pay a bit more and get tools that last for years. My 400D is an awesome piece of kit that i couldnt live without. So if you ask me id say -Dont be cheap get the real deal
  7. andersson.j
    andersson.j What's a Dremel?
    25 Mar 2005
    I've had a few of those cheaper ones. They usually don't last long and are very weak.
    Also dremel is way overrated! Check out the Proxxon IB/E instead.
  8. Digi
    Digi The not-so-funny Cockney
    23 Nov 2009
    I never got the hype of these tools. What can they do that you can't do with hammer and chisel or hacksaw and butter knife? Tsk.
    (yes I just haven't used one..)
  9. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Jeez you know you're on a geeks site when it starts reviewing rotary tools....Still I'm interested and thanks!
  10. DarkFear
    DarkFear What's a Dremel?
    14 Oct 2003
    I have a sudden urge to try and spray my kinda-similar ugly, gray dremel knockoff lime green now....
  11. Combatus
    16 Feb 2009
    Yep, we mentioned this in the review - sadly this thread wasn't compatible with the Dremel Flexible shaft we have.
  12. andrew8200m
    andrew8200m Modder
    4 May 2009
    Sweet! Looks like buying custompc is not needed anymore given that pretty much all reviews in the mag end up on bit-tech the minute the mag gets superceeded with the following months.
    Its a good review though so ill try not to derail too much.
  13. Combatus
    16 Feb 2009
    We'll take that as a compliment! :D
  14. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Bought a similar one (as a previous person mentioned, they make this model for multitudes of brands)
    6 months of sporadic use: dry solder joints caused unit to fail.. resoldered myself.
    6 more months - motor burnt out.
    Word of warning :)
  15. Jipa
    5 Feb 2004
    Then again, atleast mine came with a 3 year warranty, so what's the big deal?
  16. Risky
    Risky Modder
    10 Sep 2001
    Miight pick one up for occasional use as my dremel is at the other end of the country.
  17. mpr
    26 Jul 2010
    They're amazing for case modding... and it doesn't hurt that you can justify the purchase to the missus (or mister) as a valuable tool for the entire house... Show the wife you can polish jewlery and cupboard trim... WIN!
  18. [WP@]WOLVERINE
    18 Oct 2003
    Try doing this with a hammer, chisel and hacksaw......
    http://img543.imageshack.us/img543/5599/800s19.jpg
  19. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Can we see pictures of the tests?
    The review seems more like an evaluation of the device based on the accessories and feel vs it's ability to actually perform? Do you not also need a reference product to be able to assign a value?
  20. V3ctor
    10 Dec 2008
    And its beautiful... Great work :)
Tags: Add Tags
