Graphics EVGA 1280MB GeForce GTX 570 HD Superclocked uses GTX 560 ti board?
Discussion in 'Hardware' started by Bungletron, 20 Jul 2011.
  1. Bungletron
    Bungletron Well-Known Member
    25 May 2010
    Hi
    I was thinking of upgrading to GTX 570 and saw this EVGA model that deviates from the Nvidia reference:
    http://www.scan.co.uk/products/1280...mhz-gddr5-gpu-797mhz-shader-1594mhz-480-cores
    However while it deviates from the Nvidia GTX 570 reference it appears not to use a custom EVGA design but looks alarmingly just like a reference GTX 560 Ti, compare:
    http://www.scan.co.uk/products/1gb-...0mhz-shader-1800mhz-384-cores-dvi-i-mini-hdmi
    I cannot find much information, nor have I found pics under the hood, I suspect the board is the same and just has the chip swapped out.
    Has anyone got a EVGA GTX 560 HD, if so can they confirm this? If it is mostly a 560 ti board and cooler is it good enough to cope with a 570 or am I better off getting the reference 570 board?
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Well, it wont be exactly the same board, as the chips are radically different. They probably just has a load of those coolers left over and are dumping them...
  3. aka_jesse
    aka_jesse New Member
    14 Apr 2011
    probably just the same cooler. i'm pretty sure that 570 has been out since the 570 came out and haven't heard anything bad about it, so i guess it's up to the job.
  4. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    I think it's just a 560 ti cooler, but i know it isn't a reference GTX 570 PCB, don't think its a 560 ti PCB though
  5. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    They definitely are not the same pcb as 560. It is the same cooler design as 560 cards. evga also has 2 other cooler designs on 570 cards. One with the fan in the back of the cooler with reference pcb which is longer, and a cooler that has 2 fans which has the non reference pcb.
    No idea how effective that cooler is on 570, but it is fairly good on the 560ti.
  6. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    The "HD" cards weren't out when the 570 was launched to my knowledge, I've been keeping an eye on EVGA 570's because I was considering buying a couple. I'd personally avoid it and try and get a reference cooled one. If it were mine I'd want all that heat out my case not warming everything else up :)
  7. jizwizard
    jizwizard Well-Known Member
    24 Dec 2010
    dont be put off by this card. i have the exact one and i have overclocked the hell out of it. this card beats my mates gigabyte 580 in all the games we play granted his is not overclocked but for the money you will not go wrong. also it runs very cool and quiet. will be purchasing another one in the next few weeks for some sli fun.
  8. Bungletron
    25 May 2010
    Just to be sure, your sig says ' EVGA 570 SC' and the one I am specifically looking at is the EVGA 570 HD SC, you have got the HD version then? EVGA do make a reference card SC version too, its about £40 more expensive tho...
  9. thetrashcanman
    18 Nov 2010
    just get a cheap stock GTX 570, EVGA or otherwise and be done with it, the reference cooler is great, they overclock well, at least the ones I've tried have and there quiet. The only advantage of that HD version in my eye's really is the display port, but seeing as you don't need a display port or display port monitor to run 3 monitor's from geforce cards or unless you have a display port monitor, there really is no point getting that HD 570 card
  10. jizwizard
    24 Dec 2010
    sorry it is the hd sc version just not put that in my sig yet
  11. Bungletron
    25 May 2010
    My intention was to get the cheapest GTX 570 model, just so happened that due to stock issues at Scan it is not the reference at the moment, it is the EVGA 560 ti cooler model plus its overclock, decisions, decisions...
