Watercooling Evga 580 Block
Discussion in 'Hardware' started by AoE, 5 Feb 2012.
  1. AoE
    AoE What's a Dremel?
    4 Oct 2011
    Started research into watercooling, basically its been brough to my attention that I may have some trouble getting a evga 580 water block? any recommendations I think i'll be going with an EK Kit, but dont include gpu blocks
  2. longweight
    7 May 2011
    Can you not just buy it from EVGA?
  3. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
  4. AoE
    4 Oct 2011
  5. thetrashcanman
    18 Nov 2010
    Yeah because EVGA are a bunch W**KERS! all cards that had torx's instead of normal screws had no Intergrated Heat Spreader on them, and yes mate that will work for definite:thumb:
  6. AoE
    4 Oct 2011
    did you have a block on it before selling? need to for 100% man before I buy this?, need it to make contact with processor.
  7. thetrashcanman
    18 Nov 2010
    No I didn't mate, they where never watercooled and just read the description of the block on scan's website if your don't believe me chum :thumb:
  8. AoE
    4 Oct 2011
    ahh i see it now, IHS_less cards :)
  9. thetrashcanman
    18 Nov 2010
    That's it, as for the rest of your watercooling gear, what else you thinking of doing, what case you using and you going with compression fittings or barbs?
    Oh and did you try overclocking the card? :)
  10. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    If you can't get the evga branded hydro copper blocks and actually want them, you might be able to get the plain swiftech ones, they are the same thing. if you wanted to go a cheaper route, and have gpu block that you can use on your next card, swiftech also do a pretty decent looking full cover heatsink to use with a universal block.
    I am still skeptical of EK nickle plated. I know they say they have it sorted but... I would still stick to copper myself if buying EK.
    Heatkiller blocks look pretty good too, might have a look at them as well if you haven't.
  11. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
