Graphics evga 6800 gt problems
Discussion in 'Hardware' started by lmeyer718, 16 Oct 2004.
  1. lmeyer718
    lmeyer718 What's a Dremel?
    30 Apr 2004
    well i just got a 256mb evga 6800 gt and a nv silencer 5 cooler. i removed the oiginal heat sink and fan, installed the nv silencer applied the thermal paste on the gpu and the 8 rams. cleaned the old thermal paste of first. seemed to go without a problem. plug fan to card installed in pc plugged a direct power connector to card. when i booted pc up first time started good booted fast and right past vmi pool stuff the screen gets all garbled. alot of colors and stays that way. turned off n on again now it goes str8 to garbled screen. whats the deal with that. i got card from newegg.com
  2. Mister_Tad
    27 Dec 2002
    did you test the card before putting the cooler on?
    the cooler may not be making good contact with either the core or the ram on the card, or you may have damaged the card when installing the cooler
  3. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    How much paste did you put on the GPU?
  4. lmeyer718
    30 Apr 2004
    i applied thin layer and more paste to the ram chips. no i didnt test card b4 installing cooler
  5. lmeyer718
    30 Apr 2004
    and now im missing one of the original spring screws from to heatsink so im gonna have trouble rma it
  6. rob_65
    rob_65 What's a Dremel?
    5 Apr 2004
    Don't know about yours, but mine had some sort of red glue around the screws, so rmaing it will not be an option if yours had this too...
  7. lmeyer718
    30 Apr 2004
    no i didnt see any red glue. so what did u do with yours?
  8. rob_65
    5 Apr 2004
    I added an Acrtic Cooling VGA Silencer NV5 and overclocked it :)
  9. lmeyer718
    30 Apr 2004
    so what do think happened? i applied the thermal grease that came with the silencer. i applied a thin layer to gpu and alot to the rams did a clean job no mess. system booted up and right b4 i could get to window my colors went. now alls i get is garbled colors.
  10. Mister_Tad
    27 Dec 2002
    2 things could have happened:
    you damamged the card when installing the heatisink
    or
    the card was duff to begin with
    either way your chances of an RMA are pretty slim
    i got my 6800 and the NV68 at the same time but the first thing i did was test the card out to make sure it wasnt DOA, kinda sucks if the card was screwed to begin with :sigh:
  11. lmeyer718
    30 Apr 2004
    how could u mess the card up on installation. im mean i have installed amd 2600 mobiles with sp97 with as5 and tornado fans with no problems. what do use as for thermal paste. did u use the stuff that came with the cooler or as5?
  12. lmeyer718
    30 Apr 2004
    if newegg doesnt rma it. whats the chances it can be serviced from evga?
  13. Mister_Tad
    27 Dec 2002
    slim to none :(
  14. lmeyer718
    30 Apr 2004
    well inspite what was said newegg.com rmaed the card. i got my $405 back. they dont have more evga 6800 gts now. any brand 6800 gt recommendations? also i saw tutorials on nv5 silencer n i dont understand how i could have messed it up. it looks simple. one question what do use to clean off the old thermal paste from the gpu. do u use the paste that comes with silencer or some as5?
  15. ElCid
    ElCid What's a Dremel?
    2 Jun 2004
    On my 9800 pro i used 91% rubbing alch. The other 9% is water, so all you do is spray it on, clean if off, let it set for a bit then go about your business.
  16. TMM
    TMM Modder
    12 Jan 2004
    yep. Alcohol is the best. i use some 99.5% stuff (its good having a dad who works in a hospital :D)
  17. fohkus
    fohkus What's a Dremel?
    12 May 2002
    newegg rmas everything. they are surely the best :)
