News EVGA announces Hadron Air mini-ITX chassis
Discussion in 'Article Discussion' started by Gareth Halfacree, 10 Sep 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Platinum
    Platinum What's a Dremel?
    25 Jun 2001
    Yep I read that as Hardon....
  3. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Finally, a manufacturer has the guts to rpovide a custom sized PSU ! This is the only way to really shrinks the size down and keeps a clever layout. Go EVGA, you have my support :thumb:
    PS: NEXT step is to get rid of this silly and fat 24pins ATX plug on motherboard. It's time to use 12V only connectors :).
    EDIT : My only concern about this : Why on earth is the ODD slot located on the right side ? What if my desk side, a wall or anything else is facing this :wallbash: ?
  4. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I thought it was a bitfenix there for a minute.
    Sent from my GT-I9505 using Tapatalk 2
  5. Cei
    Cei pew pew pew
    22 Mar 2008
    Still one thing I can't find the answer for: What connectors are on the PSU?
  6. defined
    defined Botch-Job
    7 Aug 2012
    why do they feel the need to create a terrible "15 year old gamer" video/trailer for the case
  7. Gareth Halfacree
    4 Dec 2007
    Made a quick update to the article: the Hadron Air is now live in EVGA's own shop, priced at €180.77 (around £153 excluding taxes.)
  8. Kovoet
    26 Aug 2009
    typical evga very expensive.
  9. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Couldn't you use one of those half sized server PSUs?
  10. GuilleAcoustic
    26 Nov 2010
    That's what this PSU is in fact. What I was talking about is that most ITX case use a full fat ATX PSU. Even if you throw a FLEX PSU inside of it, you'll still have all this space wasted since it has been tought for an ATX one.
    PSU should move to something maybe longer but thinner. Example this HP PSU (ok it is only 100W :D)
    While being thin, it has a large fan, which is better than the common 40mm fan used in FLEX PSU.
  11. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    Glad it wasn't just me!
  12. Gareth Halfacree
    4 Dec 2007
    You have no idea how many times I had to re-read what I'd written, just to make sure there were no typos. Add to that, I was so busy looking for the obvious that I almost sent it live with an instance of EVAG instead of EVGA...
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    :hehe::lol:
  14. CrazyMods
    CrazyMods What's a Dremel?
    6 May 2010
    I'll buy one. TBH this is the sexiest, cleverest case I've seen in years.
  15. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    As mentioned in the other thread started by atc, love the design, though I'm tepted to say, wonder if there'll be a mATX version?
  16. Cei
    Cei pew pew pew
    22 Mar 2008
    Right, one of these is sitting on my desk, so I can (try) to answer burning questions.
    So far, I'm a little disappointed how vague EVGA are about the case. Even the manual doesn't tell you the maximum height permitted for CPU coolers, or other things like PSU connectors. However, it's a tiny tiny box that takes a GTX 780!
  17. GiantKiwi
    GiantKiwi What's a Dremel?
    6 Jan 2011
    Bit late to the party, just bought one, will see how it goes, hopefully the PSU will run the system I bought to go inside it.
