Graphics EVGA back plate
Discussion in 'Hardware' started by Kovoet, 15 Oct 2013.
  1. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Anybody know where to get back plates for evga cards in the UK
  2. GeorgeK
    18 Sep 2010
    When I bought mine the only place I could find wasn't actually in the UK but from EVGA themselves... Scan occasionally has some but none at the minute. What card's it for?
  3. jinq-sea
    15 Oct 2012
    I'm guessing it is for Kov's new 780 SC...
    I'd drop EVGA a message directly - if such a thing exists, they'll probably be able to sort you out :)
  4. Kovoet
    26 Aug 2009
    It's for a EVGA GeForce GTX 780 Superclocked ACX
  5. Kovoet
    26 Aug 2009
    Thanks guys
  6. Kovoet
    26 Aug 2009
    George are they simple to install
  7. Kovoet
    26 Aug 2009
    Right I have pre=ordered one from scan as they have an outstanding delivery from the 11th of this month. Let's see what happens
  8. GeorgeK
    18 Sep 2010
    They're very easy to install if you have the right tools - I didn't and had to buy a tiny torx screwdriver but other than that, dead easy. I didn't remove the heatsink just took the old screws out, put the backplate on and put the new screws in. Not sure if it actually did anything for the temps but it looks awesome :D If not the service from the evga shop was actually really good :thumb:
  9. Kovoet
    26 Aug 2009
