Graphics EVGA GTX 670 - 2GB or 4GB - Advice
Discussion in 'Hardware' started by ACallander, 15 Aug 2012.
  1. ACallander
    ACallander What's a Dremel?
    24 Feb 2010
    I run a 27" CrossOver Led-P 2550x1440 and a 24" Samsung SyncMaster P2250 and I don't know if I need the 2GB or the 4GB card?
  2. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    I think if you had 3 27" screens, then it would be worth it
  3. Parge
    16 Jul 2010
    Will you be gaming on both? I'm guessing just the 27".
    In which case the 2Gb should be fine.
    Out of interest, how do you find the crossover?
  4. ACallander
    24 Feb 2010
    Yes, I will only use the 27".. The other display will be my gpu/CPU temp gadgets and such.. Nerd info area :).
    I found out about the crossover awhile ago from overclock.net topic. Finally pulled the trigger and purchased one last year.
  5. Parge
    16 Jul 2010
    No, sorry, how do you find it? Is it any good?
  6. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    pmsl nerd info area. I think we all should have a nerd info area now
  7. ACallander
    24 Feb 2010
    Found it from overclock.net forum for the Korean monitors. Search for crossover led..
    I love mine. It's the same display on apple cinema displays but is a grade lower. I have one green pixel but its not noticeable when I game.
  8. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    I've gone for the 2gb versions.
