News EVGA launches 'Untouchables' EPower V VRM card
Discussion in 'Article Discussion' started by bit-tech, 19 Sep 2017.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Surely power hasn't been holding pack any GPU architecture for a few years now? I understand this is fully intended for pro overclockers using LN2 and such, but even with 3rd party cards specifically designed to be pushed to the limit, that limit is in the frequency the GPU can go to I would have thought.
    Might be good for absolute fine control and stability, though.
  3. TheMadDutchDude
    23 Aug 2013
    Power delivery definitely has been holding back cards on liquid nitrogen. The Titan X Maxwell was pulling over 500A per card on LN2.
  4. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    500 amps per card?! really?!
  5. TheMadDutchDude
    23 Aug 2013
    Easily. It was tripping OCP which was at 500A. :(
  6. Margo Baggins
    28 May 2010
    i'm almost certain 500 amps would melt a PC psu :D and the motherboard, and the graphics card!
  7. TheMadDutchDude
    23 Aug 2013
    Nope. 500A at say 1.5v is only 750w drawn at the GPU side, not through 12v. ;)
  8. Margo Baggins
    28 May 2010
    I thought you meant 500a @ 12v, as that would be more like 6000w
    was confused :D
  9. Anfield
    Anfield Multimodder
    15 Jan 2010
    Nvidia has been enforcing a voltage limit on card manufacturers for years, if they allow the voltage to go above a certain point they can't hold nvidia responsible for anything, which is why all the premium price cards with their gajillion phases and ultra abusable caps have close to zero variation in OC potential.
    Of course that limit can be modded and then with LN2 added to the mix the sky is the limit.
  10. TheMadDutchDude
    23 Aug 2013
    Nah, 500A at GPU ish volts with frequency to match. :D
    The limit is only to do with extreme cooling. You'll never even dream of air or water cooling that kind of power usage. :)
  11. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    500W per card, surely?
  12. TheMadDutchDude
    23 Aug 2013
    No. 500 amps. Read the post above. :)
  13. Anfield
    Anfield Multimodder
    15 Jan 2010
    I was talking about the nvidia imposed limitations that make mods like the ones mentioned here necessary.
    (yes, obviously completely pointless on air / water)
Tags: Add Tags
