Evga Motherboard problems
Discussion in 'Tech Support' started by Bosephus, 5 Jul 2006.
  1. Bosephus
    Bosephus What's a Dremel?
    5 Jul 2006
    I have an evga motherboard and it is making some serious racket. I have water cooling over the CPU but there is another fan on the motherboard right beside the graphics card and when it starts to spins it makes a wierd sound like the fan is rubbing on something i checked it out myslef but no avail. =/ Please any info would be helpfull.
  2. DougEdey
    5 Jul 2005
    Sounds like the ol' northbridge fan problem, you can easily get a water cooled block for it, but you should know that if you watercool.
  3. Bosephus
    5 Jul 2006
    So is that like another water cooling system? It would seem kind of redundant to have 2 if at all possible? Do you know what is making the noise? I know its the fan but how do you stop it from making the noise? Maybe a bit of cleaning? Maybe one of the bearings is shot? Also the temp gauge reads FF not really sure if that has something to do with it. I really have no clue and really dont want to have to ship it all the way back to the dealer just to get a week from now =/
    A bit more info
    CPU-3800+ X2 AMD
    Ram-1 Gig
    Videocard-7800GT
    Powersuplly-500W
    Thats about all i know about it
  4. DougEdey
    5 Jul 2005
    The fan is probably just loosing its bearings.
    You can normally get Zalman silent heatsinks for them, you'll have to look for evga replacement northbridge coolers.
  5. Bosephus
    5 Jul 2006
    Thanks for the info ill check it out
    Edit-Would unpluging it untill my new heatsink/fan arrives harm my computer at all?
  6. atanum141
    22 Jul 2004
    Dont unplug it, if its the nforce4 series board they create rather a large amount of heat, so unplugging it will do you no favours, unless you do unplug it but leave it on there and get like a 80mm fan seperately cooling the thing insted of the fan on the actual unit.
  7. Bosephus
    5 Jul 2006
    Installed new fan today. Fixed the problem completely no more wicked sounds and add 1024 more ram in the form of 2 more sticks of 512 2.5 cas latency memory. Bit of info if anyone reads this that has some issues.
    #1. Unplug the comp from the wall cause that can cause an issue. :D
    #2. Label all plugs before starting project. Including the plug slot.
    #3. Clips on the BACK of the motherboard release the old fan. Might require you remove the mobo completely from the tray.
    #4. Finally-Read the instructions. I didnt for the first 20 min then i finally dug em out of the trash can and bam it went together real smoth now i have a quiet fan to keep my mobo cool as ice.
