Graphics EVGA PowerLink Power Cable Management with 980ti Classified
Discussion in 'Hardware' started by GaryP, 24 Oct 2018.
  1. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Does anyone know if the EVGA PowerLink Power Cable Management unit works with the 980ti Classifield. I can't find it on the EVGA site, it fits 980ti's (06G-P4-4998) but not showing up on the 06G-P4-4998-KR model.
  2. Big Elf
    23 Apr 2009
    I never knew these existed, just ordered 2, thank you.
    Maybe buy from Amazon and return if they don't fit. Alternatively I've found you usually get a good response either raising a technical support request with EVGA or posting in their forums. If you check out the videos (Scan have a pretty good one) you might be able to get an idea if it'll fit your card just from the visuals.
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Based on their FAQ the 06G-P4-4998 is supported.
  4. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Thats what I posted originally, but the KR isn't showing. The classified is a bigger card physically.
  5. GaryP
    GaryP RIP Tel
    31 Aug 2009
    I have just ordered two from CCL. A fiver each plus £3 posting. If they don't fit my 980ti Classy and my 680 Classy I am still running on my spares rig I'll sell them on and get some of it back.
  6. Corky42
    30 Oct 2012
    The last two digits of the EVGA product code define the warranty period. (link)
    GaryP likes this.
  7. GaryP
    GaryP RIP Tel
    31 Aug 2009
    Result. Thanks mate.
  8. Guest-56605
    Guest-56605 Guest
    @GaryP, they're adjustible and have both six and eight pin socket types included so you should be just fine Gaz :thumb:
    GaryP likes this.
  9. Vault-Tec
    30 Aug 2015
    I run one on a Fury X lol.
    Have just ordered and received one for my new build. Good, they are.
