News EVGA X570 (AMD) Dark motherboard launched at US$690
Discussion in 'Article Discussion' started by bit-tech, 22 Sep 2021.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Mr_Mistoffelees
    26 Aug 2014
    Someone on Tom's Hardware pointed out that the logo on the heatsink, looks more like DORK than DARK. Can't unsee that now...
    monty-pup likes this.
  3. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    /me files under "HOW MUCH???!?!!?!?! :jawdrop:"
    EDIT: Not mentioned in the article:- This is an E-ATX mobo.
    DeViLzzz and Mr_Mistoffelees like this.
  4. von_stylon
    von_stylon uber micro
    23 Apr 2009
    Why only 2 dimms? :eyebrow:
    DeViLzzz likes this.
  5. Arboreal
    21 Jan 2011
    So you can super OC it, as supposedly fitting 4 DIMMS can limit maximum 'OC powah' in that sort of setup.
    A bit limiting and niche, methinks
  6. sandys
    sandys Multimodder
    26 Mar 2006
    Really nice board, I like the rotated socket and dimm, works well on my nas x570 board, dual 2.5G is nice but at this price point could have been 10G, I do like the reset CMOS on the rear plate and internal power and reset buttons, my gigabyte board does not have this and I miss it a lot particularly when dicking about with memory on the bench, came in really handy on my x399. Nice to have some cooling fans on the vrms too.
    2 dimms is fine, I only have 4 dimms as I have come down from quad to dual channel and reused, 4 dimms tend to lead to lower clocks, in my asrock I cannot do more than 2933 but 2 sticks will do 3200 as it doesn't have fancy OC options.
    I would have bought 2 fast dimms for my gaming desktop for higher clocks/lower latency etc, not done too bad with 4 dimms at 3933 though, 4 oc'd dimms in a stack like I have do heat up, not sure how the rotated dimms would cool in a typical case like mine, I have a ram cooler that comes on to keep them under 50C.
  7. andrew8200m
    andrew8200m Modder
    4 May 2009
    Not been featured in any records yet...
    Given how 4 dimms populated shows a small improvement over 2 dimms in a fair few benchmarks, why would 2 dimms be a think on such a board? Just wire it so the closest 2 dimms are the two to populate for frequency and latency based fund and the two further away are for everything else.. might get some records then.
  8. DeViLzzz
    DeViLzzz What's a Dremel?
    8 Jan 2015
    Paying $690 US for a motherboard with only 2 dimms is ridiculous. Bad enough paying $690 US but geeze. Also as for any overclocking well overclocking hardly gets you much these days so another reason to not spend an idiotic amount on a mobo. Honestly this just points to the direction pc gaming is headed and it is that it is going right down the toilet. The greed of these companies is ridiculous.
  9. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    It's almost like they didn't want to make a high-end AMD board after all, so are trying to price themselves out of the market.
  10. wyx087
    15 Aug 2007
    It's 4 rank vs 2 rank that gives the small improvement. You can buy dual rank memory sticks giving same performance as 4 single rank sticks.
    It's all about signal termination. This is why manuals always say to insert the sticks at furtherest away slots for each channel. Also, dual slots give best possible signal quality because there won't be any interference picked up by unpopulated sockets
    Personally, I like the fact it's something completely different. It's not another carbon copy of every other motherboards out there that only differentiate itself with PCIe configuration and ArrrrGeeBee.
    Also interesting that it's not a x570s but it hasn't got a chipset fan.
  11. sandys
    sandys Multimodder
    26 Mar 2006
    My asrock board is the same, interestingly my x570s gigabyte board has exactly the same chipset ID, makes me think that these S chips have been out in the wild for sometime with manufacturers.
    It's a niche board for a niche audience, I can't imagine they expect to sell many hence the price.
  12. Anfield
    Anfield Multimodder
    15 Jan 2010
    Wouldn't surprise me one bit if X570s was literally just a binned und undervolted X570 tbh.
  13. sandys
    sandys Multimodder
    26 Mar 2006
    Seems quite nice.
Tags: Add Tags
