Scratch Build – In Progress Evolution
Discussion in 'Project Logs' started by Editor22, 19 Jan 2010.
  1. LooseNeutral
    LooseNeutral New Member
    13 May 2010
    What'cha got planned for wire sleeving? Noticed the XSPC pump top, I've got it slated for a project. Would love some feed back from you on it! SU model it, please! If you can find the time. I'm in droolville! :D
  2. Cheapskate
    13 May 2007
    Looking gooooooood.:D I kinda like how it looks with the top panels off too. It has a floating motherboard thing going like that.
  3. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Ohhh a check list:thumb:
    I always say to myself, make a check list! And yet, it normally goes like this:
    -make a check list!
    -naaah ill figure it out as i go
    -but it will be so easier
    -naaah i´m to awsome for that
    6 months later
    -DOH :wallbash::wallbash::wallbash::wallbash:
  4. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    I'm thinking black sleeving, blue highlights and black / blue shrink. I should be able to give a bit of feedback on the pump top in the next few weeks when the rest of my WC gear arrives :)
    oo Does this mean I get the cheapskate seal of approval! :hip:
    lol that made me laugh. I have to admit this is the first list I've actually printed off.. I do loads on the computer but then delete them about a day later. Think its something I'll do more often now given how much it sped up the process :D
    Chanc3 likes this.
  5. The boy 4rm oz
    10 Apr 2008
    Editor22 likes this.
  6. Editor22
    3 Jan 2009
    Big +rep man! I couldn't find a diagram anywhere. followed it and I now have the switch working like a charm :) using the ring light for HDD activity just for now as I didn't have a 3 pin LED pwr block to hand.
  7. Chanc3
    Chanc3 New Member
    22 Jun 2010
    That looks seriously good. +Rep for awesomeness
  8. waffle
    waffle New Member
    10 Apr 2008
    I'm a little late subbing, but your build looks awesome!! I'm new to all this and tight on funds.:sigh: I'm learning/planning now and hope to build in the next year or so. Thanks for the inspiration. Looks great so far!:thumb: Reading 19 pages took a while lol
  9. The boy 4rm oz
    10 Apr 2008
    Cheers mate, glad I could help.
  10. Combatus
    Combatus Bit-tech Modding + hardware reviews Staff Super Moderator
    16 Feb 2009
    Latest shots look stunning mate and I'm using you're and mrdbristol's work as a guide on how to use Phenoptix's LEDs! I have a 1m long strip waiting to be installed in Warpcore! Can't wait to see this with some water inside! :D
  11. Editor22
    3 Jan 2009
    Sorry for the late reply guys :eeek:
    Thanks Chanc3 :)
    Thanks Waffle, I'm glad you managed to stick through the whole log :) feel free to use anything you see in the log or improve on it :D I love the thought that I could inspire someone to create something :thumb:
    Thanks Anthony :) the LED tape is fantastic and pretty easy to work with once you remember how to solder lol. Should create some great effects on warp core :)
  12. LooseNeutral
    13 May 2010
    You've really helped me out with that check list idea. I have my own of sorts but to have a printed version to keep on track is great even in planning stage. Now updating build files for same! Too many files spread all over hell and back! Thanks! :D
  13. Editor22
    3 Jan 2009
    Theres something great about checking something off a list isnt there :D
    I know exactly what you mean about masses of files spread everywhere! in the end I just made a folder labelled evolution crap and dragged it all in there lol.
  14. phenoptix
    phenoptix New Member
    16 Aug 2006
    Been a while since I was on. Just spotted our "sponsored post". Great work, very proud to be a part of it. Stunning build.
  15. Fabou
    Fabou New Member
    22 Apr 2010
    Really nice progress. It's really taking shape.
  16. Editor22
    3 Jan 2009
    Thanks Ben :)
    Thank you Fabou :rock:
    I guess I should say that Evolution is still on going but the past few weeks have been insanely busy and I haven't really had much time for logging.
    However there has been some progress and some extra little bits have been modified and added :) If all goes to plan I hope to run a leak test this weekend so there may be an update in the making if I can find the time to sort through the pictures.
    Thanks for staying with me :thumb:
  17. Editor22
    3 Jan 2009
    Well I found the time today to install the loop :D
    I'm using the 3/8 tubing and compression fittings as the 1/2" ones I'm after are going to be out of stock for a while :duh:
    Not a huge selection of pictures to dazzle you all with but its a start :) if all goes to plan then I'll update with some more shots tomorrow,
    Enjoy.
  18. LooseNeutral
    13 May 2010
    MMMMmmmm! SWEET! BEAUTIFUL HUE O BLUE! MOOOORE! please :D
  19. stonedsurd
    11 Mar 2009
    Oooh! that's pretty!
  20. tkgclimb
    tkgclimb man it's all harder than it looks
    18 Jan 2010
    I'm pretty sure I just got my mind blown:jawdrop:
    This is awesome, if I make anything half as good I'll be stoked.
