Windows Excel Continuous Ranking help
Discussion in 'Software' started by jopers1986, 3 Sep 2009.
  1. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    Hi,
    Need some help with an excel function. i need to rank a set of numbers, the highest needs to be 1 etc.
    However, there will be duplicated numbers, and the standard rank function tackels this by missing out numbers so if i had the following numbers:
    10, 10, 10, 3, 5, 5, 1, 0
    It would give the rankings
    1, 1, 1, 4, 4, 6, 7, 8
    And what i need would be
    1, 1, 1, 2, 2, 3, 4, 5
    I've found formulas that do the 1st and 2nd, and one that does what i need, but requires you to control shift enter, which i really don't wnat to do....
    anyone know how i do this?
    Thanks
  2. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    I'm not sure if this is really what you want but, anyway...
    1. Put the numbers you need to sort in a column
    2. Sort them on descending order
    3. Put a 1 in the first cell at the top of the next column
    4. Use the formula =IF(A2<A1,B1+1,B1) in the cell below it
    5. Drag the formula down to the bottom of the column
    Code:
      A     B
    1 10	1
    2 10	=IF(A2<A1,B1+1,B1)
    3 10	=IF(A3<A2,B2+1,B2)
    4 5	=IF(A4<A3,B3+1,B3)
    5 5	=IF(A5<A4,B4+1,B4)
    6 3	=IF(A6<A5,B5+1,B5)
    7 1	=IF(A7<A6,B6+1,B6)
    8 0	=IF(A8<A7,B7+1,B7)
  3. jopers1986
    7 Jan 2005
    haha, yeah i've got this running, but there is other attached data, so when you then sort by another field, that sorting all goes tits up... bit of a pain really!
    Thanks tho, any other ideas?
  4. jopers1986
    7 Jan 2005
    This works...
    Code:
    =SUM(IF(B4>$B$4:$B$38,1/COUNTIF($B$4:$B$38,$B$4:$B$38)))+1
    BUT it gives a descending rank (highest number is ranked lowest, and i need it the other way around.
    IS there a formula i could run off the new rank to flip it around?
    OR to do what i want....?
    Thanks
  5. Mach
    Mach What's a Dremel?
    30 Jul 2008
  6. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Code:
    1+)))83$B$:4$B$,83$B$:4$B$(FITNUOC/1,83$B$:4$B$>4B(FI(MUS=
  7. jopers1986
    7 Jan 2005
    Chortle chortle.... if only that worked, a mate at work gave me some code which fixed me up nicely:
    Code:
    =IF(C4="N/A",99,IF($C$4:$C$38>=C4,SUM(IF(FREQUENCY(IF(LEN(IF($C$4:$C$38>=C4,$C$4:$C$38,0))>0,MATCH(IF($C$4:$C$38>=C4,$C$4:$C$38,0),IF($C$4:$C$38>=C4,$C$4:$C$38,0),0),""),IF(LEN(IF($C$4:$C$38>=C4,$C$4:$C$38,0))>0,MATCH(IF($C$4:$C$38>=C4,$C$4:$C$38,0),IF($C$4:$C$38>=C4,$C$4:$C$38,0),0),""))>0,1)),0)-2)+IF(B5=MIN($B$4:$B$38),1,0)
