Excel help needed please
Discussion in 'Software' started by MightyBenihana, 28 Nov 2017.
  1. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    I am having a problem whereby I want a cell to -1 from another cell unless that cell = 0. If 0 then I want it to remain at 0 (i.e. not go into negative numbers)
    For example:
    If A1= greater than 0 then -1, if A1= 0 then return 0.
    I hope that makes sense and someone can help.
    Thanks
  2. Xlog
    Xlog Active Member
    16 Dec 2006
    =IF(A1>0, A1-1, 0)
  3. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I’d use
    =IF($A1>0, $A1-1, $A1)
    Depends whether you want to force 0 or copy the value I.e. this will allow a negative value.
  4. MightyBenihana
    8 Sep 2011
    Thanks guys
  5. MightyBenihana
    8 Sep 2011
    OK I am closer to a solution but I think my explanation wasn't great.
    The answers above leave me with zero because there is nothing in the Feb '18 box to minus 1 from. The cell is blank, I need the formulae to provide the number.
    I will try to explain better:
    I have sheet Jan'18 which shows installment payments remaining, so in Jan there are 6 payments remaining, in Feb '18 there will be 5 and so on until zero payments remaining. What I am trying to do is get a formula that automatically reduced the number of installments across the sheets until zero and when it reaches zero it remains at zero and doesn't go to -1.
  6. bawjaws
    bawjaws Well-Known Member
    5 Dec 2010
    The easiest way of doing this is probably to use the MAX function - i.e. = MAX (A1-1,0) will reduce A1 by one but the lowest it'll go is 0.
  7. MightyBenihana
    8 Sep 2011
    Could you explain how to do that, please?
  8. MightyBenihana
    8 Sep 2011
    Think i got it
