Windows Excellent guide to CoreAVC 1.9.5 using CUDA and general DXVA acceleration for anime
Discussion in 'Software' started by Guest-16, 18 Jul 2009.
  1. Guest-16
    Guest-16 Guest
  2. Igniseus
    Igniseus What's a Dremel?
    5 Mar 2006
    Really? So the supposed "best" decoder produces worse results than say FFDSHOW quality wise? I've had it purchased for a while now using ATI hardware and on my high-end screen 1080p blu-rays do seem noisy.
  3. Igniseus
    5 Mar 2006
    What's also annoying is that 720p blown up on a lesser quality 37" TV looks better!
    For comparison:
    My PC - benq fp241w @ 1920x1200, ATI 4870, with CoreAVC on Windows 7 playing blu-rays
    Living room TV: Samsung (bottom range) 37" 720p playing HD content off Sky.
  4. Guest-16
    Guest-16 Guest
    CoreAVC was only the "best" decoder in terms of very low CPU usage, it was never better quality than a tweaked FFDShow.
    You certainly don't need CoreAVC for blu-ray disk playback alone - what software do you use? Something like PowerDVD should use DXVA to use ATI's UVD.
  5. Igniseus
    5 Mar 2006
    I use TotalMedia Theatre 3.5 which uses its own internal decoder I believe, but doesn't appear to be much better in quality, and certainly not as nice as the TV+Sky.
    I used to rip all my HD-DVD's and Blu-rays and play them through WMP or MPC-HC using CoreAVC, but after filling 4TB of HD space I decided to just buy Blu-ray playback software instead even though I'd lose the ability to play my movies across the network (I have a NAS).
    Is there a way to set up TotalMedia Theatre to use FFDSHOW and if so, is there a guide to setting it up for optimal 1080p quality?
    Thanks
  6. Guest-16
    Guest-16 Guest
    Try PowerDVD 8/9 and also see what options there are in ATI's control panel - there maybe noise reduction and motion detection.
    Either that or go to AVSForum
  7. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Very Nice, thanks for the info... any chance of making this a sticky... or adding a link to it in the other "Looking for 1080p playback advice? Follow this thread" thread that is currently Sticky in the Tech Support section??
    Even though I have managed to setup smooth 1080p playback using the previous guide, this one is a lil more in depth and would be usefull if it dont get berried.
    :thumb:
  8. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    CoreAVC seems to be a lot better than it used to be. I don't notice any more noise or blocks than FFDShow. This is using 1.9.5
