Windows Exchange server - help needed.. 2 instances, which do i need?
Discussion in 'Software' started by mushky, 1 Dec 2003.
  1. mushky
    mushky gimme snails
    24 Mar 2003
    my server is running win2k pro + MS exchange 2000. I'm really short on disk space so ive been looking at things to delete to make more space.
    I noticed that there are 2 instances of exchange on the disk. One in D:\ and the other in D:\program files.
    The contents of these two are similar but not the same. They are both over 3GB. (there are only 10 accounts!)here is a tree diagram
    Also, there is another partition G:\ which is labelled Exchange, but is only 3mb big. In here is a folder called MBX and another called Public folders.
    If anyone can tell me what i can get rid of, if anything, i'd be really really grateful.
    Thanks in advance,
  2. BlackTower
    BlackTower What's a Dremel?
    1 Aug 2003
    The one in Program files looks like a full Exchange 2000 install but dont take my word for it :D
