Scratch Build – In Progress EXO-S: TRANSPORT CASE DONE!
Discussion in 'Project Logs' started by Mystikal0412, 31 May 2011.
  1. jamsand
    jamsand Minimodder
    21 May 2011
    Looking at the log and it's rough state "looks pretty awesome very industrial grunge kind of look"....*see's it sanded*..."WTH! it looks completely different....almost, elegant, futuristic O.O"
    loving it so far keep up the good work
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I'm loving this, looks beautiful :)
    How heavy is it?
  3. Mystikal0412
    Mystikal0412 Safety First, Think Twice!
    31 May 2011
    We still have to measure it, but it is still at the powdercoatingshop (nice word for Scrabble!). But don't think it is very heavy, because it is not! Give you the details once it is back from the shop!
  4. Mystikal0412
    31 May 2011
    It weighs 8.1kg. Not too bad in my opinion!
  5. Mystikal0412
    31 May 2011
    See attached the photo's after the powdercoating. We are not really satisfied with the coating so far (not visible on the photo's), so we brought the case back, so they can re-do the coating.
  6. amagriva
    amagriva Minimodder
    13 Jun 2009
    Wow! And it's light too...(By the look I thought the weight was at least double) Which defects do you encountered with the podwer coating? At a first glance it seems good.
  7. Mystikal0412
    31 May 2011
    There are 3 defects at this moment (all not visible on the photo's).
    -On some places there was dust/dirt on the coating, which is visible and you can also feel it.
    -There was a 'drop/bubble' of powedercoating on the PSU cover.
    -On the pieces which are solderered there are small holes. Probably the stainless-steel sanding caused small pits in the softer solder. Those were not visible on the metal, but now are, due to the black.
    The last issue is the least difficult to fix, but also the coating company will try to come with a solution for that problem. Problem 1 and 2 will be fixed when coated once more.
  8. Gentleman_Dingo
    Gentleman_Dingo What's a Dremel?
    30 Aug 2007
    It look awesome so far. Shame they couldn't get the coating right the first time. But at least they're willing to give it another coat.
  9. pAcMan
    pAcMan What's a Dremel?
    22 Jul 2011
    Really cool and intresting design, if it is okey with you I would like to borrow some of the designs, the "cut lines" if you understand what I mean, just the pattern on the PSU cover, all creeds go to you of course.
    And Subscribed btw :)
  10. 7x3 ])3A7H
    7x3 ])3A7H What's a Dremel?
    30 Jul 2011
    Great metal work man, I love this project. ;) Black case with Red leds will be awesome. :)
    Subscribed. ;)
  11. Mystikal0412
    31 May 2011
    Of course that is okay. It would be an honour to see other people being inspired to our case-design. What else can we wish for! I am really anxious to see, how you will implement it in your project. Do sent me a link when you have started!
  12. pAcMan
    22 Jul 2011
    I makes me happy that I can borrow your design :)
    I'm not really sure just yet how I will implement it, but I just knew that I wanted to implement it when I saw your design, but I will probably do it in plexi (easier to get hold of here) :hehe:
  13. Mystikal0412
    31 May 2011
    Okay, I wish you all the luck with your new project!
  14. Karrek
    Karrek Minimodder
    7 Jun 2011
    I'm liking this alot. I really like the unique motherboard mount.
    I hope that round 2 of powdercoat goes well... I want to see more!
  15. Mystikal0412
    31 May 2011
    The case will be fixed this Tuesday. Hopefully it is just fine, they charged us 75 euro additional (first round was 45 euro).
  16. Mystikal0412
    31 May 2011
    The Exo-S is back from the coater!
    A few pictures of the person who solved all problems. It took him over 6 hours, but we are happy with the result! The paint is still wet on the pictures, therefor it shines more than when the paint is dry.
    To the next phase!
  17. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    I might have missed something, but isnt powder coating where you put the hole thing into a electic fluid where the paint will stick to the metal and then throws it into an oven to cure? :D
  18. robi09
    robi09 What's a Dremel?
    20 Jun 2011
    A M A Z I N G!
    Grat job mate!
  19. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Not necessarily. Some coaters use special powder coating guns that charge the particles and then blast them onto the subject.
  20. Mystikal0412
    31 May 2011
    Not necessarily... See below ;)
    And like I said before we had some issues and therefor they have coated the case (in the first place) and after that they 'sealed' it, filled it, sand it and after that put a special paint on it.
    So it is not only powdercoating anymore! Nevertheless it is as strong as powdercoating and the colour is what we expected!
