Expanding the H220 in 2017?
Discussion in 'Watercooling' started by AT0MAC, 10 Dec 2017.
  1. AT0MAC
    AT0MAC ~PC ninja~
    8 Jun 2008
    I have one of the still alive and well Swiftech H220 AIO's, not the X model, the original one.
    I actually only bought it not so long ago as a clearance sale, completely new, so its been in use under 2 years by now.
    I want to expand it, in the beginning with a extra 120mm radiator, because I already have the space in my build and a radiator unused (was cleaning out some things today and found a rad in my closet).
    Im thinking that would make my temps even better, so why not.
    Only thing is, what size tubing do this AIO use?
    I mean, the fittings it comes with dont look like any standard size, so I wonder what size I should use to expand the loop with and also, what soft tubing should I use?
  2. AT0MAC
    AT0MAC ~PC ninja~
    8 Jun 2008
    But that seems to be for the 220X model and newer, not sure if that would work on the original?
    Also, dont seem to be in stock any more...
    I might have found out by watching this video here:
    He mentions to use 3/8 by 5/8 fittings in the other end, thats 10/16mm as far as I know?
    So if the original tubing is also that, then this should be pretty easy to do so
  3. RedFlames
    23 Apr 2009
    Yes i mis-read which is why i deleted my reply...
  4. galvinD
    galvinD New Member
    6 Nov 2017
    How's your research so far?
  5. David
    David RIP Tel
    7 Apr 2009
    I have the Swiftech Apogeedrive II sitting in a cupboard somewhere - I'm pretty sure the barbs/fittings were standard G1/4", so you could use practically anything. It's a very long time since I owned a H220, so I can't remember - does the pump block have integrated barbs?
  6. AT0MAC
    AT0MAC ~PC ninja~
    8 Jun 2008
    Yes it's using integrated barbs.
    Anyway I have given up on this plan and would like to build a proper loop instead, even made a new thread about that so surprised to see you resurrected this one
  7. David
    David RIP Tel
    7 Apr 2009
    Someone else did - I just didn't notice the post dates. :)
