Scratch Build – In Progress Expedit | by Brodholm [XBMC & NAS]
Discussion in 'Project Logs' started by Andreas | Brodholm, 26 Mar 2013.
  1. Andreas | Brodholm
    Andreas | Brodholm Minimodder
    12 Jan 2013
    Welcome!
    I thought I would share a project I am doing on the side of my "model 01" project. :D
    Concept
    It is designed to act as a powerful media computer and NAS. The chassis is designed to be anonymous with a simple and clean design. It is made to fit in a IKEA Expedit shelf.
    Feel free to ask me anything! And be sure to leave a comment on what you think! :thumb:
  2. Andreas | Brodholm
    12 Jan 2013
    Specifications
    • The same size as a IKEA Expedit shelf.
    • Can handle ATX form factor.
    • Can handle long graphics cards.
    • Six slots for 3.5" HDD
    • Two slots for 2.5" SSD
    • Can handle 160mm PSU
    • Two 120mm fans takes fresh air from the front and blows it out in the back.
    Components
    Unclear right now.
  3. Andreas | Brodholm
    12 Jan 2013
    Reserved again
  4. Andreas | Brodholm
    12 Jan 2013
    I will start of the first update with some renders! Next update with some actual progress will follow soon.
  5. Andreas | Brodholm
    12 Jan 2013
    I was originally not planing on doing a log for this project so I unfortunately did not take that many pictures of the work from flat aluminium sheets to folded and anodized parts. BUT I did these at the exact same time in my other log "model 01". So if you are interested in that process you can check it out there. It was done the same way. But after this I will be sure to take lots of photos!
  6. jrs77
    jrs77 Modder
    17 Feb 2006
    The HDD-cage is really well designed :thumb:
  7. Korvus
    Korvus May contain traces of sanity.
    14 Apr 2011
    Huh. Nice idea with the integration into that unit. I might do something similar for my HTPC if I make it later this year :) Thanks for the inspiration!
  8. Guest-23315
    Guest-23315 Guest
    Looking pretty trendy :)
  9. Hukkel
    Hukkel James' minion
    20 Dec 2012
    It you put in a lot of HDDs they produce heat. Do you think they get enough cooling like this?
    Anyway; great project AGAIN!
    You must be very good at designing these things into a cuttable plan.
  10. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    Great thinking. I know I have at least two places where this could go in my place.
  11. Andreas | Brodholm
    12 Jan 2013
    Thanks! It is designed to fit with lian li's hdd mounting gourmets. So some of the design is borrowed from them. But there is a lot of modifications as well.
    That is what I want to hear! I wish you all the best of luck with your project!
    Thanks man! This was acctually put together over a weekend before I sent the other project to the laser cutter. I was like "hmm, I may need a media computer also, maybe I should build one to".
    About the HDD's, I think I will be fine to be honest. They will only be 5400rpm and they also hibernate when they are idle. And two 120mm fans should be able to take care of it anyway.
    Thanks man!
    This is probably something that some big case company could make into a profitable product. It is a really simple design that most people would have use of.
  12. tekonivel
    tekonivel Minimodder
    14 Jul 2012
    You Sir are Awesome!
  13. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Damn Andreas! I seriously love your design work!
  14. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Fantastic idea. I'll watch this one.
  15. faxiij
    faxiij Minimodder
    25 Jan 2011
    Awesome. Could even think of a start-up business model.
    Build those in bigger numbers and you can build a nice server-rack that looks so much better. Should have a high wife-acceptance-factor too!
    Sweet sweet sweet!
    I will add though I'm not sold on the cooling solution. If you could measure some temps when in use that would be cool, I'd be very interested in that :)
  16. Andreas | Brodholm
    12 Jan 2013
    Thanks a lot!
    I have not tried with the cooling yet. But I think it will be sufficient. I will move over my current computer to this chassis probably (gtx 580, 2500k, 16gb ram, 4hdd's and a SSD.
    Worst case scenario, I will have to get some lower wattage components.
    But I hope and think that two, 120mm fans will do the job.
  17. HybridCore
    HybridCore What's a Dremel?
    20 May 2011
    Very nice. This is beautiful work so far just like Model 01.
  18. Andreas | Brodholm
    12 Jan 2013
    Thank you kind sir!
    Can inform you that the next update will be this Friday. Editing pictures as I writing this! :)
  19. Andreas | Brodholm
    12 Jan 2013
    Update #3 Sound Dampening Material
  20. stuartwood89
    20 Aug 2008
    Oh WOW. I love this! I tend to agree about the cooling HOWEVER...
    I'm running a similar cooling setup (2 x 120mm fans exhausting, no intakes), and CPU temps are fairly decent, even on the stock Intel fan. I would possibly try and add one or two fans at the front, just to encourage some fresh air into the front. The grille is already there, so perhaps some 80mm or 92mm fans behind it.
    Just a thought, but your design work is awesome :D
