Case Mod - In Progress Experiment Nr. 5 (Final pics on page 8)
Discussion in 'Project Logs' started by p0Pe, 17 Feb 2014.
  1. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Haha, it will probably go up on the wall as an art piece:p Its even more abstract with the error in there.
    Thanks man! I hope to get the same reaction when you see the correct panel!
    Good guess, but not correct. The panels are as thick as they should be (11mm).
    Nice eye there, but not correct. If you look VERY closely, you will also see that the square you talk about is in fact two triangles. It will be easier to see on the finished panel, as that will have a better surface quality.
    BINGO! The programmer turned the material the wrong way around when he did the programming:wallbash:
  2. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Funny, what damage a tiny little mistake in the wrong place can do.
  3. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Tiny and tiny. I think it was kind of a biggie:D Going to pick up the top monday, and then I can order the acrylic inserts! Should be an interesting week!
  4. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Pssssssst:worried: I iz still alive!
    Some progress! Since I recently got a deadline for this thing, a few things has happened. The overall build has gotten some touch ups to clean up the insides, mostly by changing fluid, and swapping the harddrive out.
    Me and my buddy Peter (Myrizzle) also found some time to do a lot of the milling, but there is still a long way to go. I will upload some pictures of the case itself soon, but for now, here is a few pics of todays progress:
    I hope to have this bad boy done within a few weeks:clap::clap::clap:
  5. Cheapskate
    13 May 2007
    LIFE! :rock:
    siliconfanatic likes this.
  6. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Eeeeeexcellent! :clap:
  7. HybridCore
    HybridCore What's a Dremel?
    20 May 2011
  8. siliconfanatic
    10 Sep 2012
    IT LIIIIIIIVES! :D
  9. Mr3D
    Mr3D What's a Dremel?
    23 Dec 2011
    Dude, this is seriously ballin'! :D
  10. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    About bloody time.....
    :grr:
  11. Waynio
    Waynio Relaxing
    20 Aug 2009
    These panels are going to look so kickass. :D
  12. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Sweet, sweet CNC action...
  13. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Thank you all! I know that I am slow, and for that I am sorry, but there is quite a few things going on at the moment:D
    None the less, I will leave you with this:
  14. Cheapskate
    13 May 2007
    Is that a render? -'cause you know we need no steeeeenking renders.
    -If it isn't, you've been holding out on us.:(
  15. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Better looking than Hexgear ;)
  16. Vognen
    Vognen Minimodder
    2 Oct 2013
    As amazing as always Hans. I hope I get the chance to see it in real life some day(hint sell me some more hardware ;) )
  17. myrizzle
    myrizzle What's a Dremel?
    23 Nov 2011
    That is not a Render, it's the actual case.
    I know, 'cause i made it :naughty::rock:
  18. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    P0pe, you teasing floozy!!!!
  19. Bygone
    Bygone Minimodder
    15 Apr 2015
    Craftsmanship as usual topnotch from your side Hans, but this design is a bit too special for me...but that is just a matter of difference in taste.
  20. griso
    griso What's a Dremel?
    9 Sep 2014
    Can´t wait for finished prictures. Excelent work.
