Modding experiments in making an acrylic drivecage... walkthrough
Discussion in 'Modding' started by eddie_dane, 28 Oct 2002.
  1. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    since I have this dead 24x drive and some more thin plexi. maybe I will try to do this. If I manage to pull it off, I will do a guide for it. The only way I can think of off the top of my head using the bend method is to create a form representing the inside dimensions of the drive casing.. I already have a form representing the dimensions of a CDRom drive, all I would have to do is trim it up a bit.. As Linear said earlier, the hang up maybe the thickness of the plexi... could throw off the dimensions of the box and make it hard to mount... /me goes off and thinks..
  2. koolshot
    koolshot What's a Dremel?
    10 Apr 2002
    Is there any reason that you bent it upwards and not down?
    Would it be easier/better to heat up the acrylic and let gravity pull it down slightly, then start flattening it against the side of the drive?
  3. eddie_dane
    31 Jan 2002
    http://forums.bit-tech.net/showthread.php?s=&threadid=18828 ;)
  4. Morphine
    Morphine weeee!
    23 Feb 2002
    thanks!
    :clap:
