Build Advice Expert Advice needed
Discussion in 'Hardware' started by Boshed, 22 Apr 2010.
  1. Boshed
    Boshed What's a Dremel?
    22 Apr 2010
    Well to keep this short, I have a PC atm but I want to upgrade it.
    I want to run several applications at the same time and when I do this the computer is sluggish and slows down.
    I was thinking of upgrading the motherboard and processor and memory.
    I have about 250 - 300 to spend
    This is what I have at the moment
    CPU Intel Pentium 4 640 Prescott (3.20 Ghz)
    Motherboard MS 7046
    Memory 2GB DDR PC-3200 RAM (4 memory slots. Max 4GB)
    Hard Drive WD1600JD-00HBB0 160GB SATA
    CD Drive Ultima-Artec DHM-1648S 16X DVD-ROM
    Pioneer DVR-109DB DVDRW
    Floppy Drive Floppy disk drive fitted
    Video Card nVIDIA GeForce 6800 GT
    Sound Card CMedia CMI9880L
    Network Card VIA Rhine III VT6105
    Creatix 405 PCI 802.11g wireless
    Modem Modem/Analogue TV tuner CTX918
    Ports - Front 1x Card Reader
    2x USB 2.0
    1x Headphone
    1x Microphone
    1x IEEE 1394 (4-pin) *
    1x IEEE 1394 (6-pin) *
    1x Phono (left) in
    1x Phono (right) in
    1x Composite in
    1x S-Video in
    Ports - Back 1x PS/2 Keyboard
    1x PS/2 Mouse
    1x Serial
    1x Parallel
    1x S/PDIF Digital Input
    4x USB 2.0
    1x LAN
    1x Firewire (IEEE 1394)
    1x Rear Surround
    1x Audio in
    1x S/PDIF Digital Output
    1x Front Speakers
    1x Wide Surround
    1x Centre/Subwoofer
    1x DVI Output
    1x 7-pin S-Video output
    1x VGA
    1x Modem
    1x TV Antenna
    1x FM Radio Antenna
    1x Wireless LAN Antenna
    If you give me any advise how to spend it please let me know thanks :rock:
  2. warejon9
    warejon9 What's a Dremel?
    20 Apr 2010
    Hi, i'm not an expert, however you could get a cheap quadcore AMD 965 for £128, am3 board with graphics for bout £90, and then spend another £90 on the ram. IT depends how much of your computer you want to upgrade, that should be quite responsive for browsing internet and general computing.
  3. IanJackson
    IanJackson Photographer & Modder
    22 Mar 2007
    This is what i got, its in american currency but yeah im not sure where you are from. The ram also has a $20 dollar mail-in rebate so its below $300 dollars with the shipping. These are also all from Newegg.com
    ASUS M4N68T-M AM3 NVIDIA Geforce 7025/nForce 630a Micro ATX AMD Motherboard
    Model #:M4N68T-M
    Item #:N82E16813131626
    $54.99
    AMD Phenom II X4 945 Deneb 3.0GHz Socket AM3 95W Quad-Core Processor Model HDX945WFGIBOX
    Model #:HDX945WFGIBOX
    Item #:N82E16819103696
    $149.99
    OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model OCZ3P1333LV4GK
    Model #:OCZ3P1333LV4GK
    Item #:N82E16820227478
    $87.99 with $20 mail-in rebate
    Subtotal: $292.97 + $8 dollar shipping?
