Expert opinion needed on a SD card
Discussion in 'Hardware' started by SKnight, 4 Sep 2004.
  1. SKnight
    SKnight What's a Dremel?
    4 Sep 2004
    I'm in the process of purchasing a SD card for my Digital Cam. and Palm. Which brand should I go with when it comes to flash memory? Is PNY SD cards reliable? :wallbash: Help, I need an expert opinion. Thanks. :clap:
  2. RTT
    RTT #parp
    12 Mar 2001
    Hi welcome to the bit-tech/the forums :) I've moved this thread to the appropriate forum... i'm sure someone who knows more about this subject than I will be along to answer your question shortly :p :thumb:
    I've never had any problem with PNY stuff though :)
  3. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    Any of the major brands should be ok, Sandisk, PNY, so on so forth, if you see them listed at most of the major retailers they should be ok.
