Other Exporting thunderbird to pst
Discussion in 'Tech Support' started by dancingbear84, 17 Sep 2015.
  1. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Just wondered if anyone knows or a way of doing this, I need to export mail that has been popped into thunderbird to a pst. Trouble is the export in tbird doesn't work and you can't import into outlook.
    It is made worse by the fact that there are about 100 folders to contend with within the inbox as well...
    If anyone has any suggestions I'd love to hear them
  2. phuzz
    phuzz This is a title
    28 May 2004
    It looks like all the programs to convert from Mbox to pst are shareware, so you might have to shell out.
    The other option would be to put all the emails you want into an IMAP email account, and then re-download them with Outlook. I guess it would be possible to set up a mail server locally rather than relying on an internet connection, but I realise that's a bit of a stretch.
  3. Digerati
    Digerati Member
    19 Feb 2011
  4. dancingbear84
    16 Oct 2010
    The export button does quite literally nothing, press it an Nada.
    I will look to do it folder by folder, but this will enable a tedious process with the massive folder and subfolder structure that they use.
    The discussion today was to get them to use thunderbird for their old mail and all new will be handled with hosted exchange
  5. Digerati
    Digerati Member
    19 Feb 2011
  6. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    What is the email account that you're syncing with Thunderbird, the provider and what connection is it over?
  7. phuzz
    28 May 2004
    Resurrecting a slightly old thread, I think this is what you need.
