Thermaltake Exsectus - Thermaltake UK Modding Trophy Powered by Scan- Back from Computex 04/07/16
Discussion in 'Project Logs' started by Maki role, 9 Feb 2016.
  1. RooiDuiwel
    RooiDuiwel What's a Dremel?
    20 Sep 2009
    LIES!!!!
    you can't fool us with those renders anymore :p :D
    :D
    THAT LOOKS JUST INSANE!!! WD
  2. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Hehe thanks everybody, hopefully things will go well with the filling and testing. Indeed the O-rings are made from scratch, they specifically fit into the channels with no extra room :)
  3. Maki role
    9 Jan 2012
    Let's fill this beauty up eh?
    After extensively fixing up seals with fittings and the pump, it all worked perfectly! I also received the last shipment of fittings too, albeit after I'd done the leak testing.
  4. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Damn, that looks incredible! :jawdrop:
  5. uerseya
    uerseya Covered in rock wool
    25 Aug 2008
    Right come here .... I'm gonna lock you in my dungeon and you can build crazy insane amazing PC's for me for the rest of your life, I'll feed, cloth and shelter you .... but you'll be locked up, heh heh !
    Absolutely amazing imagination and work !
  6. Turbz
    Turbz What's a Dremel?
    17 Mar 2015
    Stunning work. Can't wait to see more!
  7. hovek
    hovek “Can’t or won’t?” Sterling Archer
    23 Jan 2014
    This is one amazing reservoir/pump/motherboard/gpu fixing installation :jawdrop:
    Tell me your secret sir...
  8. Vault-Tec
    30 Aug 2015
    Jokes aside this is quite easily going to be the best Thermaltacky mod ever.
  9. Cheapskate
    13 May 2007
    That might not be too bad, but I'd worry about how he would dress you.:worried:
    I'm still calling 'render'. I'm pretty sure those dudes are a Skyrim mod.
  10. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Thats just Alex's camera...it is obviously a stoner....
    Looking good,needs moar cowbell.
  11. Maki role
    9 Jan 2012
    Thanks dude :thumb:
    Not sure you want that, I've been told I'm very high maintenance :p
    Thanks, should be a steady stream of content over the coming week too
    Here's to hoping, got so much left to do and no time to do it in :/
    There'll be much ding ding dong when I get stuck in tomorrow :naughty:
  12. Arboreal
    21 Jan 2011
    Amazing stuff, that acrylic work and those purple screws...something amazing every build
    Is that you with the esteemed Immersa hiding behind you over at Parvum Towers?
    I MUST photograph & post my custom Parvum ITX - white on a white background isn't a good option :sigh:
  13. CaseLurker
    CaseLurker What's a Dremel?
    15 Mar 2016
    Holy...........................
    Subscribed.
  14. Maki role
    9 Jan 2012
    That'd be me cowering behind the lens as Shaun, Justin and Steve check the material thicknesses :p
    Thanks!
    Welcome aboard!
    UPDATE!
    Time to get some ACTUAL MODDING going eh?
    Now for a normal build I really quite like the width of cases like the Core X31, but for something like this it's a little... much. The X31 is a biggish case already, don't really see the point in making it even bigger when the hardware is fairly modest.
    So I decided to cut it in half down the middle and reduce the width by 80mm or so.
    Taped off and prepped for cutting
    Yeah it's a bit smaller now
    Removed all the troublesome parts on the bottom panel
    New aluminium panel in, going to be finishing it tomorrow
    Test fit with the waterblock, gives an good idea of what the layout will be
  15. B NEGATIVE
    8 Aug 2011
    I think its great that UK modders are embracing the integration ethos,we certainly have a style of our own now....and about time too.
  16. Maki role
    9 Jan 2012
    Indeed, I also like how we all have our own takes on it too. You can tell apart a build designed by you, me, JR23 or Imersa etc.
  17. B NEGATIVE
    8 Aug 2011
    Exactly,nothing cookie cutter about it and each with their own idea. The UK scene has been stale for a while,this is pure F5.
    So glad I invested in my tools now...
  18. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Inspiring work as always, Thank you Maki! :rock:
  19. Cheapskate
    13 May 2007
    I find it funny that most of these case mods are, "F your case. I do what I want." -as it should be.
  20. Maki role
    9 Jan 2012
    Man I wish I had the space for even a tiny CNC router, would open so many doors
    Thanks Bill! :thumb:
    Aye, anybody can simply build in a case and make it look pretty, where's the fun in that? Now this, this is much more exciting.
    ____
    UPDATE
    I only realised how few pictures I took after I stopped... Shame really as it makes it look like I didn't do much haha. Was in the workshop for most of the day today, lots and lots of structural work going on atm. The motherboard waterblock is now firmly in place, along with the rear and roof panels.
    The main structure is now very sturdy. You might have noticed that I'm keeping the side panel rails, they're going to serve a handy function later.
    The roof rails were still too big, so I cut them down to size and attached them to the panel
    Whilst this might not look particularly different to the last image in the previous post, it really is. I've cut up a huge amount of the remaining case pieces, many of which are rather useful.
