The front panel audio and Firewire connectors will not reach from the mainboard's upper right corner to the front when using the Lian-Li PC V1000 and a MSI K8N2 Neo Platinum. How do I extend them or where in the US would I buy them?
if you're any good with a soldering iron .. just cut them up somewhere in the middle .. (one by one is easiest i think ..) so u wont have to mess with connectors ... solder a piece of electirc wire inbetween, and put some heatshrink around the soldered contacts ... should work perfectly good luck modding
yea you could solder on extentions (solder + heatshrink or electrical tape) ive realy never seen specific extention cords i would reccomend cat5, it has 8 pairs
