A/V Extension Cable, loss of quality?
Discussion in 'Hardware' started by Treacles, 12 Aug 2011.
  1. Treacles
    Treacles Member
    7 May 2011
    Im thinking of getting a decent-ish pair of headphones (Probably Senheisser around £50 or so) and want to know wether using a 2 metre 3.5mm extension cable would lessen the quality at a noticable level? Im usually a little bit away from my computer when im using it so i doubt it would reach using the attached cable.
  2. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    Just as long as it's reasonable guage wire (16-22awg), there shouldn't be any problem.
  3. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Headphone typically have a pretty long cable.
    My Audio Technica has 3 meter cables which is huge (for me at least)
  4. Treacles
    Treacles Member
    7 May 2011
    I was thinking more along the lines that, the more connections, the more interferance in the audio, rather then the actual wire lessening quality as i was going to go for as high quality a cable as i could anyway :)
    In my experience they've only ever came with 1-1.5 metres :O But i generally buy quite cheap headphones anyway... I'll have a look around on the Sennheiser website to see if they show the cable lengths
  5. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    I don't expect any problems unless you're using crappy stuff with bad contacts... A quality cable with gold plated plugs shouldn't affect anything whatsoever.
  6. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Frankly, with a £50 pair of headphones, unless you're using an extension lead made from a piece of string, you probably wouldn't be able to notice any great difference.
  7. Cookie Monster
    Cookie Monster Well-Known Member
    27 Aug 2003
    I have a pair of Sennheiser 465HD's, out the box they came with a cable which must be around 3meters long.
  8. lamboman
    lamboman New Member
    25 Jul 2006
    Just make sure that you use a decent quality cable, nothing drastically bad. As said by Flibblebot, you won't notice a massive difference.
    That said, they connections are the area that are going to be the biggest changers of sound quality. So if I were you, I'd look at a new cable (and it's tidier too, of course).
  9. Treacles
    Treacles Member
    7 May 2011
    Yeh just checked the Sennheiser website and the ones i want (HD205's) have a 3m long cable, guess i probably wont need the extension cables! (Hopefully :lol:)
  10. The_Beast
    21 Apr 2007
    If you do buy a cable don't be a douche and buy a Monster cable. Just get a quality cable without breaking the bank
  11. MSHunter
    MSHunter Well-Known Member
    24 Apr 2009
    Sennheisers come standard with 3meter cables. If you need more your doing something badly.
