Hi I converted my external drive to NTFS but now when I move thing into it I cant get rid of the it says "cannot find specified pathways" Any ideas
I have done a little searching for you but the only tip I can find is to try reassigning the drive letters. You can do that by going to: Control Panel Administrative Tools Computer Management Storage Disk Management In this menu find the drive with the problem and right click it, select change drive letter and paths and then change the letter to something not currently in use. I think you get a warning that you must accept, good luck.
