External Hard Drive Questions
Discussion in 'Hardware' started by Guest-23315, 20 Feb 2008.
  1. Guest-23315
    Guest-23315 Guest
    I've had a V1 Western Digital 60Gb Passport 2.5" HDD since Christmas 2005. It was great, until it died today, as when I plugged in the USB-B cable, the USB mount came of its PCB..
    So, now I want a new one, but I havn't really looked at any of the reviews of them. So I wanted to know..:
    Is it worth getting E-SATA over USB, and with E-SATA HDD's do I need an external PSU?
    I'm really after ~200-250GB in a 2.5" enclosure.
    So, what would you say about this?
    Also, can I take the 60GB IDE HDD from the busted PCB and shove it into one of these to use/sell on aswell?
    Thanks. :thumb:
  2. MixWizard
    MixWizard What's a Dremel?
    16 Jan 2007
    could you not get a new pcb connector and solder new one on?
  3. Guest-23315
    Guest-23315 Guest
    Probs, but I'm a retard with a soldering Iron. Also, the case the HDD came in is pretty battered up.
  4. SaII
    SaII What's a Dremel?
    7 Jun 2006
    my friend has that one, he says he love it. fast transfer and portable :p
    I think it comes with a case too.
  5. MixWizard
    16 Jan 2007
    orite fair enough. as for the one your looking at thats quite reasonably priced and they are good HDD. With the E-SATA i think im right in saying you need to power it separately as power of sata isnt available yet
  6. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    esata is definitely worth it, but make sure you get one with usb as well. and esata has no power. you will need a brick for it.
    yes, as long as the busted adapter hasn't fried the hard drive's controller as well.
