Storage External HD or HDD + Enclosure
Discussion in 'Hardware' started by Amjedm, 18 Oct 2014.
  1. Amjedm
    Amjedm Minimodder
    2 Sep 2003
    I took delivery of a brand new Seagate 2TB Desktop drive this week and unfortunately, it failed the first test I ran (short generic).
    Apart from that, the other thing was a very noticeable and annoying hum/vibration.
    I'm now thinking of buying a Western Digtal desktop drive or buying a WD Green drive and an enclosure (USB 3.0 3.5" SATA HDD Hard Drive Caddy Case Enclosure)
    Some advice please
    Do the external WD drives suffer from this hum/vibration? Don't they get hot with a lot of use?
    Would an enclosure (above one has a fan) with WD Green be a better option - this works out around £10 more expensive than option 1.
    Thank you in advance.
  2. Big Elf
    23 Apr 2009
    All of the 3.5" external hard drives I've had have been relatively noisy but the 2.5" Hard Drives are generally a lot quieter. You can put it on a foam base which will get rid of most of the vibration/resonance. These Toshiba Stor.E 2.5" drives are very quiet.
    I use one of these docking stations for convenience but unless it's mounted on foam it also has a lot of resonance.
    Amjedm likes this.
  3. Amjedm
    Amjedm Minimodder
    2 Sep 2003
    Thank you.
    I'm going to exclude the 3.5" drives from my shortlist now.
