Notebooks External HDD - USB 3 or eSata?
Discussion in 'Hardware' started by [DE]FreD_S, 27 Jul 2012.
  1. [DE]FreD_S
    [DE]FreD_S Certified Specialist of Awesomeness
    6 Jan 2002
    Hi everyone,
    I'm currently looking into external Harddisks and I can't find a decent review of USB 3 vs eSata that isn't at least one year old. Does anyone know of any current comparison or can anyone just tell me which one is "better" for day to day work?
    I know USB 3 is theoretically faster but what about real world experience?
    Cheers,
    Fred
  2. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    Seriously, I tried looking for an esata external, and it was just so much easier to find one that was USB 3. Unless of course you buy a dock, in which case those are fairly cheap at the cost of carrying a bare drive and dock around.
  3. Shirty
    18 Apr 1982
    USB 3 is a much neater interface and I'd imagine much more future-proof seeing as it's only just really starting to be adopted. eSATA never really took off did it?
    Perfect world is a USB 3 portable SSD, so you get a single wire, compact and speedy solution. Still stupidly expensive though.
  4. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    USB3 for ease of use and compatibility
    eSata for if you do lots of large file transfers
    PocketDemon likes this.
  5. GeorgeK
    18 Sep 2010
    I thought that USB 3.0 was faster than eSATA?
  6. PocketDemon
    PocketDemon What's a Dremel?
    3 Jul 2010
    usb3 is faster for some uses, but, in this instance -
    (a) you're limited by the speed of the HDD(s) used
    (b) & with sata drives, esata is a native interface whereas there's an extra translation layer to r/w to usb.
    Now, theoretically, (b) should only have a major impact on small file transfers d.t. the added latency...
    ...but, whilst i've seen testing that goes either way, personal experience of using both (i have identical drives that i connect via usb3, all with effectively zero fragmentation so writing large files to the same cylinders on the matched drives, which i use to back up the non-raided drives in one of my DASes), personally i have always found that esata is noticeably quicker.
    That said, as the use i'm putting them to is not time sensitive, i'm either aiming to put these backup drives into 3rd build (making the esata DAS the backup) or getting an 8 bay usb3 box...
    ...partially the latter's about not needing to add an extra card for more esata ports but also, unless you're dealing with arrays when there can be advantages to esata, as The Beast says, usb is much simpler to work with...
    ...esp if you want things to be plug'n'play between machines.
  7. The_Beast
    21 Apr 2007
    USB3 has a pretty fast start speed, but once you start transferring a large file, and get into the "meat and bones" of the file, the speed drops considerably.
    If I were to buy an enclosure today for travel, it would be USB3. But if it was for backups, eSata for sure.
    Also, don't go by theoretical maximums, they are just that, theoretical.
  8. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Unless you have esatap on your pc and can find esatap drive I would just go with usb option. Otherwise you end up having to use 2 cables or even worse another power brick.
  9. [DE]FreD_S
    6 Jan 2002
    Hi Guys,
    thanks for all the replies - so it hasn't changed much, has it?
    I'd be using the drive for backup and partially for VMs... looking at prices for the size I'd need though I think I'll be going with a USB 3 drive from Western Digital (the 1TB Passport).
    Any recommendations from your side though?
    Cheers,
    Fred
  10. The_Beast
    21 Apr 2007
    I always build them myself. I find a HDD I find reliable (I like WD, and used to love Samsung) then find an enclosure that fits my needs and put it together myself
