Modding External Power article help
Discussion in 'Modding' started by LiL_MJ, 25 Jul 2004.
  1. LiL_MJ
    LiL_MJ New Member
    4 Nov 2003
    Hi im planning on doin this mod but not too sure about the parts need as i cannot find them in maplins.
    was wondering if anybody has tried this mod and could supply some codes from maplins of which i need.
    i c on the article the parts were purchased from Rapid Electronics but i have a maplins down the road so prefer to pick up :)
    thankyou
    http://www.bit-tech.net/article/76/
  2. inzane86
    inzane86 engineer with an axe
    15 Jan 2004
    If it's so close then go down to the shop and ask for the things u need. Why do you need codes for that? If you cat memorize them write them down.
    3 x 2.5 mm DC Power Socket(it doesn't have to be 2.5mm pick the size you like best, and a suitable plug)
    1 x 5.25" Disk Drive "Y" splitter power cable
    1 x PCI cower... look at the back of your pc... :idea: or try pouting the sockets in a different place... in a floppy cower for example. :thumb:
    Heat shrink insulation ask at the shop.
    And happy moding :dremel:
    sry if my spelling is bad.
  3. RaptorRed
    RaptorRed New Member
    31 Aug 2003
