Electronics External Power Mod
Discussion in 'Modding' started by Mark, 7 Jun 2002.
  1. Mark
    Mark What's a Dremel?
    6 Jun 2002
    Hi,
    Im currently modifying my Coolermaster 201 case & came across the article for powering external devices, im looking at getting a tweakmonster light strip ( http://www.thecoolingshop.co.uk/tcs/comersus_viewitem.asp?idproduct=341 )but it comes with a standard molex connecter & as im adding the light strip to the underneath of my case the standard molex connection isn't ideal. That's where your mod comes in, im a newbie sofar as wiring bits up goes & was wondering how to wire the molex into the 2.5mm dc power plug that is featured in your mod.
    Any advice would be gratefully received.
    :D
  2. zz300
    zz300 What's a Dremel?
    7 Mar 2002
    It'll be more obvious once you have the plug & socket in hand. From a molex--yellow=12v and black=gnd, (red=5v but you'll not need it for this).
  3. Mark
    6 Jun 2002
    Nice 1! Thanks for that, just ordered the bits from Rapid so hopefully I wont fry my eyebrows trying to do the mod now!:lol:
