Networks extreme Lag
Discussion in 'Tech Support' started by planem997, 10 Jun 2012.
  1. planem997
    planem997 What's a Dremel?
    12 May 2009
    Dear fellow Bit-techers
    Over the last 24h's or so, when using any application that uses an internet connection, on the desktop im using. I get points when there are extreme lag when nothing will happen, then the internet will start working again. and over and over it goes. I don't know what has caused this or how to fix this. maybe one of you has a solution.
    Thanks
    Adam
    picture of network spikes (computer was left untouched before this screenshot was taken): https://www.dropbox.com/s/a5b1yqtb431uz5s/network useage.png
  2. bsp
    bsp Minimodder
    25 Dec 2010
    Have you checked your machine for malware?
  3. planem997
    12 May 2009
    I don't know what caused it but its gone, could just be the ISP being F**Ked up. swept the computer for malware and virusing and all that crap but nothing found. did give me time to go though lots of old files and delete stuff, got rid of 200 GB :p
  4. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    ping your router, what does it show
    Tracert 8.8.8.8 (google public dns) what does it show? any major lag points?
    ipconfig /flushdns
