Extreme Lian Li by Ediejo
Discussion in 'Article Discussion' started by WilHarris, 3 Jul 2006.
  1. g3n3tiX
    g3n3tiX Minimodder
    3 Jun 2006
    I like it, but I have 2 questions : -sound level ? Is there any damping on the compressor ? the fans near the upper parts look silent, so are the ones near the cpu ?
    - weight...as well as dimensions, like Stwongbad said.
  2. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Now pick it up, that'll really impress me.
  3. Stwongbad
    Stwongbad What's a Dremel?
    8 Jun 2006
    Ive read that project log and I couldnt wait till it was on the frontpage as he totally deserved it for all that work I still cant get over the size ; could we get some measurements on the height on that thing?
    SFF,mid tower, full tower, extreme lian-li....
  4. Sathy
    Sathy What's a Dremel?
    17 May 2005
    Pretty nice mod you got there, although a bit too big for my taste.
    Obviously alot of attention to detail which is always a plus in modding and clearly you have talent in putting things together!
    Being such a huge case, I wonder how much the whole system weight is....something like 30 kilos? Got some sort of special rig for transporting it or?
  5. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    I have this guys on my msn list lets just say this guy is super skilled and always willing to help out and give his idea on how to try a mod. This mod is A+++
  6. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    Hello bit-tech readers!
    First of all so sorry for my late reaction.
    Thank you all for your responses. Here are some of the answers to your questions.
    The weight of the Extreme Lian Li, with the wooden container for transport to LAN party’s.
    90 kilo =14.173 Stones = 198.42 Pound
    Ramble, somebody else toke the photo when I was lifting that case in the wooden-container. I can not find it. Make a new one later. ;)
    When I go to a lanparty, I transport it with my VW Caddy. See the wooden container on the left side. ;)
    The height 24 cm, for the prometeia 2 cm plexi, 59,5 cm for the Lian Lipc-70, again 2cm plexi and at last 24 cm for the water-cooling.
    Total height from the case 111,5 cm = 44 Inches
    The greater part of the case is in the bottom-half, so I can asure you, the system is quite solid on the ground.
    About the noise. Only when it starting up it makes some noise. What you hear then is the Prometeia. When the Prometeia is running on -45 degrees Celsius, the noise level goes down. There are three 120mm fans for the water-cooling. And four 80mm case fans inside the case. Even when the system is overclocked it has enough cooling power so that the case fans can do the work on 7 volt. When it’s running on stock settings I can switch down the water-cooling fans. The water-cooling part is separated from the case. So the water transports the heat outside the case. It is not influenced by the heat from the case. I think that makes a big difference between using water-cooling radiators outside the case.
    This was my first casemod and I worked out till the end. I do my best to show some more casemods from me here. I am still working on some more cases now.
    Some special thanks: To my sponsor. Point of View. And to Frenkie for translating this artikel.
    Thank you for the compliments. I hope to see you soon.
  7. Frenkie
    Frenkie Lets mod the world!
    3 Jul 2006
    I really love this mod. I was fortunate to spend two days close to ediejo and his case on the Hardware Info exchange last year. That case is one mean mother :)
  8. Reason.Renegade
    Reason.Renegade What's a Dremel?
    11 May 2006
    Aweosme custom case, just proves if you put your mind to it anything is possible, well done !!!!
  9. Solidus
    Solidus Superhuman
    26 Dec 2005
    il give you a fiver for it! take it or leave it *hint* take it, take it** :p
    Amazing mod dude!
  10. un1ty
    un1ty What's a Dremel?
    4 Jul 2006
    Hey ed mate,
    its a bit late isn't it?
    i guess the thread @ GoT is about 6 months old now.
    tho.. it stays a cool mod!
    great job!
    by the way, are you planning to upgrade to conroe yet?
    i'll see you again, at GoT :rock:
  11. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    90 kilograms?!?!?!?!? *me faints*.
  12. customh
    customh conflagration.
    22 Oct 2005
    Sweet mod, insane size!!!
  13. Ediejo
    31 Jul 2005
    Hey un1ty, it is never to late for the frontpag from Bit-Tech. :naughty:
    the thread @ GoT is almost 2 years old.
    Now I am not planning to upgrade to conroe.
    Also no chance for return to GoT. I like Bit-Tech verry much.
  14. ShadowWings
    ShadowWings What's a Dremel?
    22 Jan 2006
    Congrats Ediejo with the frontpage on Bit-Tech.
  15. Ediejo
    31 Jul 2005
    Thanks ShadowWings.
  16. neander
    neander What's a Dremel?
    30 Apr 2006
    Same weight as Neander (must stop the corona's I think :duh: ) ... Not bad Ed, Great Case, superb work :clap: You must have a great example .... and I would like to see how the story continues ... the future must be ..... :thumb:
    cu soon .. :dremel:
    ps : check the impact of such a case on the bumper of the car ;-)
  17. Ediejo
    31 Jul 2005
    Thanks Neander and all the best in the future............. :thumb:
    See you soon ;)
  18. misterkholl
    misterkholl modMode:on
    18 Jun 2006
    Hi Ediejo! thank YOU for the inspiration!! it's fantastic!!! :thumb:
  19. zachfp
    zachfp What's a Dremel?
    18 Oct 2006
    Ediejo,
    I love your mod. I have the same Lian Li and was lookingforideas when I came across yours. It truely inspired me. I did have a few questions for you, though. How did you get the leaking light effect on the front panel? Did you place spacers between the case and the front panel mounting legs? Also, how did you polsih the drive cages?
    Thanks for the inspiration!
  20. nulio
    nulio What's a Dremel?
    30 Dec 2006
    Hi :D
    I loved this mod :jawdrop: It has some details that I really really loved.
    About your question zachfp, I think he polished the cages like this
    Yet I have now other question for Ediejo, I've seen this "structure-thing" some times in one mod and another. What is this called?
    I'm thinking starting, with some help, my first mod, and a thing like this would me a lot. :rock:
    EDIT: I just noticed now that the last post was some months old :worried:
    Cumps,
    nulio
Tags: Add Tags
