Case Mod - In Progress F117A05. All black, Stealthed A05
Discussion in 'Project Logs' started by D-Cyph3r, 29 Sep 2009.
  1. D-Cyph3r
    D-Cyph3r Gay for Yunosuke
    31 Aug 2008
    A fairly basic little log, nothing special. ETA for completion is around end of the week. ;)
    The brief:
    A small, modestly spec'd, air cooled machine to use until I have the funds to build a proper watercooled high end machine based around the half price GD65 I got a couple of weeks back.
    The mods:
    Dual 120mm radiator/fan cut in roof (done by Pheonixdancer)
    Black acrylic floor (to cover up triple rad cut done by Pheonixdancer :p)
    Black acrylic drive bay/PSU stealth sheet
    Front panel, LED, PSU and fan cables braided black
    Basic window cut
    The Hardware:
    AMD Phenom II 720 Black Edition w/Thermalright TRUE
    Asus M4A78T-E 790GX
    4GB GeIL 1333Mhz DDR3
    Western Digital Caviar Black 500GB
    512MB ATI 4870 w/Thermalright T-Rad2
    Cooler Master 700W
    X-Fi Extreme Gamer
    The Start:
    How the front will look:
    Measure twice.... cut half a dozen times. >.<
    Ugh, will be sleeving these asap:
    Looks a good fit?
    It wasn't. Well, not quite. Did that thing we all do where we forget to account for the side panels >.< But i'll sort that later....
    But the stealth look is already showing through:
    Hoping tomorrow to get the 2nd piece of acrylic cut and the floor trimmed up so the side panels can go on.... may even start of the window. Thursday will be a mad braiding day and hopefully some hardware will be transferred over.
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    what the hell, did you chew on the motherboard tray!
  3. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    Another PC-A05!
    Is it the week of A05 mods? :D:D:D
  4. D-Cyph3r
    31 Aug 2008
    Done by the previous owner, I think he used a tin opener. :p
  5. Burnout21
    9 Sep 2005
    looks like a rat did it.
    FIX IT OR YOU GET FIXED! lol!
  6. The boy 4rm oz
    10 Apr 2008
    Nice start, looking good.
  7. D-Cyph3r
    31 Aug 2008
    Does covering it up with a motherboard count as fixing? :p
    Anyways, found a simple top down view of a F-117 to cut into the side panel, cant decide to have it nose up or nose down though:
    What do we think?
  8. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    It looks like an ace of spades dude, can you put it at an angle lie nose pointing to 2 o clock?
  9. Pazu
    Pazu What's a Dremel?
    10 Aug 2005
    For a side window design, I would have it face forward. Give it a better visual sense.
    Glad to see another A05 mod. This is like a crazy week for A05 mods. :D
  10. jhanlon303
    7 Sep 2006
    Actually to most Americans it is surprisingly recognizable as a Nighthawk. Sideways would be better I think. You have the mechanical shape done well, the tail, the wings. No other shape like it. Too bad they retired them. Wonder wha'ts hiding beyond F-35?
    john
  11. D-Cyph3r
    31 Aug 2008
    Hello!
    Got the last piece of acrylic done this morning, aswell as the side panel. Even though I armed myself with a dremel, jigsaw and coping saw I was surprised that I only needed the jiggy (and the drill to do the starting holes).
    Came out pretty darn sweet if I say so myself, the tight corners need some filing but the lines are straight and there were no "OMG NOOOOOOOOOO!" moments. As you can see I went for a diagonal angle that looks pretty good:
    Close up to show where the tidying needs to be done:
    And the 2 pieces of acrylic which will hide the PSU and drive bays from view when the panel is off... aswell as adding to the angular, stealthy look:
    Now I gotta go find a lighter and get braiding. :D
    Cheapskate likes this.
  12. Burnout21
    9 Sep 2005
    shame your photo studio is on top of a toilet.
    Other than that, it looks pretty sweet, stick a mobo in there so it hides that rat mess. lol!
  13. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Watching. Patiently.
  14. D-Cyph3r
    31 Aug 2008
    It's the only place in the house theres enough light for my G1's crappy camera. :(
    Will get some decent pics up if we can find the digicams USB lead. >.<
    Anyways, case cables are sleeved, not sure whether or not to use the stock Lian Li fans or get some Yates....
  15. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    Nice idea with the window!!!
  16. D-Cyph3r
    31 Aug 2008
    New PSU from Cookie Monster come today. Got the hardware installed and it's practically finished now (the first time i've ever set a deadline for a build and made it).
    A couple of things need to be done before I can call it finished though:
    -Decide what fans to use. Buy 'em, braid 'em and hook 'em up to the yet-to-be-installed Scythe fan controller.
    -Sort out the HDD/drive bay bezel situation (3.5"-5.25" stabilizer covers the holes the bezel tabs secure into).... Might have to resort to l-brackets and super glue.
    -Install some filter material over the intakes. The amount of dust that came out the A17 was pretty shocking. :S
    Anywho, piccies!
    :D
  17. Pazu
    10 Aug 2005
    I like how you managed the cables. It's a tight squeeze in there, I know!
  18. The boy 4rm oz
    10 Apr 2008
    I really like how you did those plexi covers to hide the drive bays and PSU, I might have to steal that idea lol.
  19. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    like it mate, nice PSU :thumb:
  20. jhanlon303
    7 Sep 2006
    It's just ALL well done.
    Your avatar words - " from Predator?" Jesse Ventura?
