Windows fahrenheit help
Discussion in 'Gaming' started by chemo, 21 Feb 2006.
  1. chemo
    chemo True Jungle Brother
    20 Feb 2005
    im stuck on the level where the murderer is at his office and being attacked by the bugs in his head. you have to press the buttons at the specified times, aka parrappa the rapper etc.
    now it doesnt seem to matter if i do the button presses slow or fast with the last commands as i just cant do it. has anyone got any tips for getting past the end of this simon says bit of the game?
    i get to the end of the corridor just to have the bug thing fall on me everytime without fail, its driving me crazy as i really want to progress with the game :(
  2. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    I just followed the commands and it worked out in the end.
  3. Hybr1d
    Hybr1d Bаnned
    13 Dec 2005
    Strangley enough, if you miss the timings he doesn't react to the bugs and freak out and after that I think you have to get the timings perfect :)
    Great game btw, it's called Indigo Prophecy if you're from across the pond.
  4. Guest-16
    Guest-16 Guest
    I just got the commands dead on and it worked. Must be seriously annoying to go through that sequence again and again.
  5. chemo
    20 Feb 2005
    werd!
    i just cant seem to get it, i try to do it as fast as i possibly can, then i try to do it with a bit of a rythm and its just wont work. there 2 types of noice signal thing that i get too, one is higher pitched and sounds like a 'good' gaming noise and the other is ore flat like a error noise but it just doesnt matter what i do i can get 2 of the good sounding noises one after the other. this is serisouly doing my nut in :(
  6. chemo
    20 Feb 2005
    ok, my swedes completely bashed in now. i think im going to have to cheat to get past this bit :(
    so has anyone got anything like a level skip thing?
  7. themax
    themax What's a Dremel?
    2 Dec 2005
    Sucks that you are stuck there. Like everyone else said, just gotta get the directions correct. I don't know if I had them spot on, but I pretty got most of them correct and just when I thought something would happen I made it through. Man, seeing this thread just reminded me that I need to finish it.
  8. Hybr1d
    Hybr1d Bаnned
    13 Dec 2005
    The ending is kinda abrupt. Just thought I'd tell you.
  9. _Kat_
    _Kat_ What's a Dremel?
    20 Jan 2006
    It's called Indigo Prophecy in the US because that's the censorred one, lol. I've played Fahrenheit and it has (a really freaking weird) sex scene in which you have to interact and then you have more sex scenes depending on how you play the game... Yeah, it only censores out the sex...
  10. Hybr1d
    Hybr1d Bаnned
    13 Dec 2005
    I noticed a few unecessary acts of digital passion whilst playing it through! :p
  11. chemo
    20 Feb 2005
    well i got rid of it today, i couldnt do that bit and it annoyed the hell out of me. stupid game.
  12. Garside
    Garside What's a Dremel?
    27 Jan 2006
    Great game, ending is absolute stool. Sci-fi B Movie esque!
  13. Bladestorm
    Bladestorm What's a Dremel?
    14 Dec 2005
    Just to check, you were using the two keypads simultaneously right ? (WASD and the arrow keys I think)
  14. chemo
    20 Feb 2005
    NOPE!!
    :geek: :wallbash:
  15. quack
    quack Minimodder
    6 Mar 2002
    I think by default you use the arrow keys and 2/4/8/6 on the number pad, at least that's how I have it set up on mine. Seems a lot easier to me, as my hands are closer together and I can time it right.
