Overclocking Failed overclock and system is going haywire
Discussion in 'Hardware' started by RagingMadman, 10 Jul 2013.
  1. RagingMadman
    RagingMadman What's a Dremel?
    6 Oct 2012
    So I have a gigabyte z87x ud4h and a 4770k. I got bored and figured if try a 5.0ghz OC.
    When I applied it, all my system does is shut down and start up. It does this continually until I switch the psu to off.
  2. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Sounds like it might be time to poke the clear cmos button.
    Or be a hipster and find the jumper. Do they even put those on boards anymore?
  3. Cei
    Cei pew pew pew
    22 Mar 2008
    Seconded, just clear your CMOS, you've pushed it too far.
  4. jizwizard
    jizwizard Modder
    24 Dec 2010
    If no clear cmos button, power down pop the battery and leave for a minute. Replace battery then hey presto she,ll work
  5. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    I suddenly feel old. I still remember when I had to set IRQ and DMA with a jump on each daughter board, set the FSB and multiplier of the CPU with jumper, when mobos had soldered not removable battery to keep the bios
  6. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    What cooler are you using?
  7. total zombie
    total zombie What's a Dremel?
    2 Nov 2009
    + what others have said! 5 ghz? good luck getting that! an everyday OC is more like 4.6ish
    Reset BIOS and go from there!:hehe:
  8. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Even 4.6 is dependant on batch really.
  9. RagingMadman
    6 Oct 2012
    Ok so clear CMOS wasn't working so I pulled everything but the CPU. It was staying on so I added the card, worked, added my ram back and it kept shutting off and in again. So i put 1 ram stick in and it worked so we added them back one at a time and the 4th DIMM would cause it to repeat. Put the bios back to 1600mhz and then the 4th and it worked so dunno what that was about.
    As far as OC'ing goes on the 4770k, I've gotten 4.8 stable on a corsair h100i running push.
  10. N17 dizzi
    23 Mar 2011
    Have you run prime 95 small fft for any decent amount of time, if so what sort of temps are you getting?
  11. RagingMadman
    6 Oct 2012
    my bad, I'm running 4.7 and hitting 78C
  12. N17 dizzi
    23 Mar 2011
    That's almost better than my lapped and IHS modded 3770, and way better than just about every review of an overclocked 4770 that I've read
