Case Mod - In Progress Fallout 4 - ZenModz (completed)
Discussion in 'Project Logs' started by Zenator, 17 May 2015.
  1. Zenator
    Zenator Minimodder
    12 May 2015
    Thank You. :)
  2. Zenator
    Zenator Minimodder
    12 May 2015
    A bit more progress, Added screws to the side panel, finished the 2nd door. And working on some more weathering textures on the grill to make it look like water has been running off it, that's still work in progress. And added hinges to the grill as well, so I can open it to clean the fan filters.
    Input and feedback is welcome.
    Cheers, Zen.
  3. bionicgeekgrrl
    bionicgeekgrrl Minimodder
    1 Oct 2009
    Wow! love it. Amazing detail.
  4. Zenator
    Zenator Minimodder
    12 May 2015
    Thank you bionicgeekgrrl :)
  5. Zenator
    Zenator Minimodder
    12 May 2015
    Cats out of the bag.
    I did not want to say want I'm trying to build till I knew if I could pull it off. Being this is my Fist try at Modding a PC. I needed to make sure I could make it happen.
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    Awesome work on the damaged look, this is definitely after the fallout. :D
  7. wst
    wst Minimodder
    30 Aug 2009
    Check spelling on that plate - it should say "fitted" not "fited" :) Digging the look!
  8. Zenator
    Zenator Minimodder
    12 May 2015
    thx for the heads up. :thumb:
  9. Zenator
    Zenator Minimodder
    12 May 2015
    Working on some red and blue caps.
    Fun little things. I think, :rolleyes:
  10. Zenator
    Zenator Minimodder
    12 May 2015
    First Tag plate done. :) Vault number Change to 111 will up date photo later.
  11. Zenator
    Zenator Minimodder
    12 May 2015
    Hi This one is a bit bigger. 520mm x 180mm.
    Been playing on the CNC.
    I'm going to be painting it as well but the font Fallout 4 will be lit with LED's
    from the bottom. and the rest will be painted to mach the case.
    the plan is to frame it and mount it to the top of the case like a billboard.
    Hope you like it. :)
    Again thank you for looking.
  12. guitarhero23
    guitarhero23 What's a Dremel?
    27 Mar 2015
    I'd like to see some more Fallout themed items in this
  13. Zenator
    Zenator Minimodder
    12 May 2015
    What did you have in mind. ? :)
  14. Zenator
    Zenator Minimodder
    12 May 2015
    I have been using the Dremel at work so far. So was thinking it's about time I got one, And here it is my first ever Dremel. :)
    I have been working on the Fallout logo. so have not had the time to do much on the case. but here is where I'm up to with the case. Such slow progress. But I guess in saying that there is a lot to do. :)
    Thank you again for looking.
    Cheers, Zen.
  15. Zenator
    Zenator Minimodder
    12 May 2015
    Hi again have not had much mod time this week. But here is what I have done so far.
    Here is a small step by step on the mounts for the billboard for the top of the case. will have two holding it up. I just need to work out the best way to make it work.
    Here is the back of the Fallout sign, still need to add weather marks but not until the mounts are fitted to it.
    Here is the face door, its just about done now. Added a spring to the left side to keep i closed. will add a pic for that later as I forgot to take one.
    Thank you again for look :)
    Cheers, Ken.
  16. bionicgeekgrrl
    1 Oct 2009
    Great work :)
    Sent from Bittech Android app
  17. Zenator
    Zenator Minimodder
    12 May 2015
    Thank you. bionicgeekgrrl.
  18. Teelzebub
    27 Nov 2009
    Looks good, nice modding mate
  19. Zenator
    Zenator Minimodder
    12 May 2015
    Cheers, Mate, :D
  20. Zenator
    Zenator Minimodder
    12 May 2015
    And the rust just keeps going. I going to start calling my self the Rust converter. I think my next build will be cleaner. :D
    Thanks for looking. :)
