Multi Fallout 4
Discussion in 'Gaming' started by mrMonkeyChunks, 2 Jun 2015.
  1. Teelzebub
    27 Nov 2009
    What can I say I bought it when it was first on sale months ago and I've bought the season ticket as well, and I've still not had the time to play yet :waah:
    I still think it's worth every penny but I've always liked the Fallout series :thumb: Enjoy I will when I get the chance to play :D
  2. Kronos
    Kronos Multimodder
    6 Nov 2009
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have eventually got it to run in my native 3440 x 1440 resolution and had to do this with various tweaks.If you use the config tool then pull up all the .ini files and change a bunch of settings to =1 which seems to work.
    I still have to figure out why it gets a bit blurry when he turns his head.
    Screenshot:
  4. Vault-Tec
    30 Aug 2015
    Yeah I remember having to do all of that when I had three monitors in surround. It was one of the reasons why I stopped using them, as some games would look stretched.
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    Any thoughts on stopping the slightly blurred effect when turning my head? Though blurred is probably not the correct word.
  6. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Okay, Virgil. **** that guy. I spent ages looking for his stupid serum, and when I went to give it to him the quest is marked as failed and he tries to kill me! Dick. Has anyone succeeded with that mission?
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
    How do I equip a weapon?
    Edit: Click right mouse button seemingly.
  8. Fantus
    Fantus Nothing to see here...
    25 Jun 2010
    Disable Motion Blur in the Settings before starting the game.
    Tab to open your Pip-Boy and go the to Inv section then Weapons. Click on the weapon to equip it (square will show next to it to indicate you've equipped it).
    Alternatively, have your mouse over the weapon you want and press Q (assuming keyboard & mouse) and then press a number to have it assigned to the number row. You can then select that number to switch to that weapon or item (I have Stimpaks on 1).
    EDIT: You ninja'd me! You can also hold R and it will raise/lower your weapon.
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    My first look outside the vault 111.
  10. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Where do you get the power armour from? I've done the BOS mission, but they haven't given me any armour - I'm still in the T-45 you get at the beginning? I've found a couple of bits of T-51 from somewhere, but not a full set.
  11. Vault-Tec
    30 Aug 2015
    Have you been on the flight to the flying BOS HQ?
  12. liratheal
    20 Nov 2005
    I think the BOS is a bit power-armour happy. I've got two suits sat in the Prydwen at the moment, I found one out in the wasteland that's still out there, and there's the one I'm wearing.
    Although after exploding the **** out of the Institute, the Minutemen don't like me much anymore
  13. Kronos
    Kronos Multimodder
    6 Nov 2009
    My Pip boy when opened is larger than my monitor which makes moving from one tab to another tricky.
    Any solutions?
    Edit: I will post a screenshot.
  14. Vault-Tec
    30 Aug 2015
    IIRC you need to change the FOV settings for the Pip Boy (and terminals).
    I thought all of this would be native by now so I think I will stick to my regular monitor.
  15. Kronos
    Kronos Multimodder
    6 Nov 2009
    Where do I find those settings?
  16. Vault-Tec
    30 Aug 2015
    Weren't they in the link you posted? I did have a read of that...
    I know in Fallout 3 and New Vegas to get them working in surround I had to do quite extensive modding of the INI files. Even when I was done it all looked a bit weird.
    Can you just set the game to run at 1440p and run it with black bars down the sides at normal ratio?
  17. Kronos
    Kronos Multimodder
    6 Nov 2009
    There are 4 .ini files that you need to go through and I have not worked out which FOV settings apply to the Pip boy yet.
  18. Vault-Tec
    30 Aug 2015
  19. Kronos
    Kronos Multimodder
    6 Nov 2009
  20. Vault-Tec
    30 Aug 2015
    All of it sadly, given that the OP is not being updated with fixes.
