Retro Fallout vs Geforce 7600 GT
Discussion in 'Gaming' started by koffan, 18 Jul 2007.
  1. koffan
    koffan What's a Dremel?
    27 Nov 2004
    Hey all,
    I recently got a copy of Fallout to play while I wait for Falout 3. Im using a Geforce 7600 GT (9.2.9.1 drivers).
    Problem is that when i start the game the screen flickers and is covered in black (moving the mouse around reveals the map momentarily); Ive tried out the various compatibility (winxp pro sp2) options but it didnt help so im all out of ideas, and unable to play a classic that i missed out on; is there any software solution to my problem?
    thnx
  2. Hells_Bliss
    Hells_Bliss What's a Dremel?
    6 Apr 2007
  3. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    if you cant find any info to help you out on the no mutants site, do what I did and grab a copy of VM and an old copy of 98/95 100% compatibility!
  4. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    once you get it working, have fun with the menu interface.
    that thing drove me nuts. FO2 wasn't much better.
  5. koffan
    27 Nov 2004
    whats VM and from where, i cudnt find any install guide on no mutants, i downloaded the game as a torrent, it only had a few files in it..
  6. Hells_Bliss
    6 Apr 2007
    VM is virtual machine, essentially you can run multiple OS's at the same time (i've got 98 2000 and 2003 VM's setup running on xp64 bit) it helps if you've got compatibility issues, ie you need fat32 or *shudders* FAT instead of NTFS etc.
    http://www.nma-fallout.com/article.php?id=1593 for the manual installation
  7. koffan
    27 Nov 2004
    ok can you point me in the direction of the correct VM (whats the name of the program?) that will allow me to play this game, im quite fond of torrents but if this is a shareware tool thats cool.
    :wallbash:
  8. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    Ah sorry I thought everyone knew what VM was. I'd only use it as a last resort since it takes alot of space, not the VM program itself but the hard drive file it creates can be a few gigs big. Here's a download link http://www.microsoft.com/downloads/...02-3199-48A3-AFA2-2DC0B40A73B6&displaylang=en and here's the bootdisk you might need if you install an OS http://www.roudybob.net/?p=123 you can also play system shock this way.
  9. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    http://www.nma-fallout.com/forum/viewtopic.php?t=1593 - Thats a guide on how to manually install, which bypasses some of the install problems. If you can install properly using the Setup.exe file, then you don't need this.
    http://www.nma-fallout.com/forum/viewtopic.php?t=5061 - this is the full help guide on how to get Fallout 1 and 2 working. It covers literally every problem and is populated by comments by many of the older developers. Amazing that you couldn't find it, since it's a sticky at the top of the tech forum on NMA :sigh:
    If that fails THEN try VM, since the above will save you a lot of bother in the long run.
    Fallout is a great game, so give it a chance before you give up on it. It's nothing to do with your video card though, it's to do with either your HDD or your OS, since these are what Fallout needs to run.
    As for the menu interface...what's wrong with it? Clear, simple and easily explained, everything is in front of you and easy to use. The turn-based style may be to everyones taste, but the menus themselves are flawless and I can't imagine what problems anyone might have with them.
  10. koffan
    27 Nov 2004
  11. koffan
    27 Nov 2004
    Thanks again all, disabling the graphics card worked for me!
