Case Mod - In Progress Fallout76 Project - PIP-BOY 2000 N-Z
Discussion in 'Project Logs' started by AKMod, 30 Dec 2018.
  1. AKMod
    AKMod Member
    29 Mar 2018
    Hello everyone,
    Cooperation project with Nvidia Taiwan
    Fallout76 game theme.
    continually updated.
    Hardware:
    CPU : INTEL CORE 9900K
    GPU : NVIDIA GEFORCE RTX 2080 Ti
    MOTHERBOARD : ASUS ROG MAXIMUS XI GENE
    MEMORY : ZADAK SHIELD RGB DDR4 3200MHz 16GB(8GBx2)
    SSD : APACER AS2280 M.2 SATA III 128G
    PSU : FSP DAGGER PRO 650W SFX PSU
    CASE : ZADAK MOAB II WATER-COOLED PC
    WATER-COOLING : ZADAK CPU WATER BLOCK
    M.2 SSD HS : ZADAK MOAB M.2 RGB HEAT SPREADER
    FAN : COOLER MASTER MASTER FAN MF120R A-RGB
  2. AKMod
    AKMod Member
    29 Mar 2018
    In-game props PIP-BOY 2000 is a concept, combined with ZADAK MOAB II WATER-COOLED PC
    Create 3D printed image draft.
  3. AKMod
    AKMod Member
    29 Mar 2018
    Some hardware:
  4. kim
    kim Active Member
    10 Jan 2016
    I've waited 'till this second post to see if it was different, but no :nono:, I still can't see any of your pictures...
  5. AKMod
    AKMod Member
    29 Mar 2018
    I can't see it after I log out.
    Thanks for reminding, I am taking a look
  6. AKMod
    AKMod Member
    29 Mar 2018
    Hello, you should be able to see these pictures now.
  7. AKMod
    AKMod Member
    29 Mar 2018
    3D printing continues to work, each component takes about 15~23
    hour
  8. kim
    kim Active Member
    10 Jan 2016
    I can see now yes, :thumb: amazing design, I won't miss to follow progress
  9. Cheapskate
    13 May 2007
  10. AKMod
    AKMod Member
    29 Mar 2018
    parts
    Preparation before polishing
    Epoxy repair
    neSSa and arduum like this.
  11. Vault-Tec
    30 Aug 2015
    Wow I can literally smell the notes being burned :D
    Absolutely love it, and the way the GPU has its own module. Very clever !
  12. storm-83
    storm-83 Member
    7 Nov 2014
    wow, this is something else!
    you have my full attention
  13. AKMod
    AKMod Member
    29 Mar 2018
    Hello, glad you liked it.
    Update some progress.
  14. AKMod
    AKMod Member
    29 Mar 2018
    Thank you man.
  15. AKMod
    AKMod Member
    29 Mar 2018
    Start grinding,
    It took about 100 hours to repair and polish.
    Trial assembly.
    Bottom painting.
    After grinding, spray surface primer.
    Prepare chipping rusty effect processing.
    kim and Vault-Tec like this.
  16. AKMod
    AKMod Member
    29 Mar 2018
    Time display accessory.
    CNC Curved surface.
    Polishing.
    Black spray paint.
    Laser cutting font.
    Detail
  17. MooZ91
    MooZ91 Member
    6 Jul 2012
    wow, this looks awesome... waiting for more...
  18. AKMod
    AKMod Member
    29 Mar 2018
    Thank you man,
    Update progress.
  19. AKMod
    AKMod Member
    29 Mar 2018
    Rusty effect coating.
    Metal effect primer.
    Aluminum paint.
    Corrosion effect.
    Surface metal effect corrosion.
    After waiting for the paint to dry, can start scraping paint.
    Surface painting, rust effect front work.
    Rusty effect.
  20. Vault-Tec
    30 Aug 2015
    Wow, that is literally amazing. One of the best rust jobs I think I have ever seen :jawdrop:
